23536 Discussions
Intel core 2 duo T5550 graphics driver
Ritesh3
Running Intel core 2 duo t5550 processor, which Intel hd graphics driver would be best fit?
AlHill
The T5500 did not provide processor graphics.
https://ark.intel.com/content/www/us/en/ark/products/32427/intel-core2-duo-processor-t5550-2m-cache-1-83-ghz-667-mhz-fsb.html
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
n_scott_pearson
As Al indicated, the answer to your question is: None. Your processor does not have an embedded graphics engine. Your embedded graphics engine is in your chipset (GMCH component).
The last version of Windows for which a chipset graphics driver was provided was Windows 7. The last driver package was version 15.17.19.2869.
For Windows 10, a compatibility driver was provided by Microsoft inbox. This driver was provided as-is. That is, Microsoft does not offer support and Microsoft has no plans to make any improvements within it.
Sorry,
