23687 Discussions
Intel driver and support assistant
vasilis
Hello.I  have  the  next  problem  at  least two years.Whne  try  to downlaod  the  driver  and  assistant uitlity  inet  redirect  very fast  to  window>  my  drivers  are  up  to date.So  i do  not have  time  to downlaod  the utility.Why  it happens?Any idea  please?
LitSurfTry
it happens Master Quicker Than Keyboard... because... You need download .exe with drivers and additionals once in life
from Intel.Com and instead of only driver... install once in life per Windows installation, Driver And Assistant Windows utility
It redirects to Windows because You do not installed utility and other stuff except Driver...
Download once in life per Windows 11 or 10, .exe for CPUs and GPUs and NPUs with a driver, and instead install driver, choose to...
...install everything else... then redirect disappears, once in life install once, enjoy updates easily automated, mind.
Driver And Assistant first must be installed in Windows as part of G.U.i. of IntelCorporation from same .exe as drivers.
