23771 Discussions
Intel driver dll file cause error in Photo viewer
FFeli3
Recently, my Windows Photo viewer often stops working when I'm using it (actually when I click the next button to view next photo). The error report shows that it is caused by igdumd64.dll
The detail report:
Problem signature:
Problem Event Name: APPCRASH
Application Name: DllHost.exe
Application Version: 6.1.7600.16385
Application Timestamp: 4a5bca54
Fault Module Name: igdumd64.dll
Fault Module Version: 8.15.10.2653
Fault Module Timestamp: 4f3aac44
Exception Code: c0000005
Exception Offset: 000000000030eb06
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1066
Additional Information 1: e9eb
Additional Information 2: e9eb3ad0c4e470c64f366286b0f8f233
Additional Information 3: 78c9
Additional Information 4: 78c965af9e4e4dca379d8e521b109a7a
Fault module version is 8.15, which is my previous vga driver (Intel HD 4000). Now I'm using 10.18. I updated this driver from 8.15 to 10.18 and didn't remove 8.15 before updating. I wonder why it still exists
How should I do to fix it ? I have tried many things to fix with COM SURRAGATE, nothing works, maybe it's not the root cause, but the dll file is
Thank you in advance!
Hello Feliks252,
Let's try addressing this error with the following steps;
  1. Open the Add/Remove Programs window
  2. Find the Intel Graphics Driver.
  3. Right click Intel Graphics Driver and select Uninstall.
  4. Follow the prompts stated by the Intel Installation Framework window to complete the process.
  5. Reboot the computer after the uninstall process has finished.
  6. Once done install the following driver version; https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81499 Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33]. Use this method for the installation; http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows...
Let me know it goes.
Amy.
Feliks252, were you able to follow the steps mentioned above?
Amy
FFeli3
Oh I'm sorry to reply very late because I have something to be busy! I have tried to re-install the version 10.18 (15.33) and now the error has gone!
Thanks for your supporting and I hope to see more good solutions from Intel in the future!
Feliks252, I am really glad to hear that!
If there is something else I can help you with, please let me know.
Amy.
