23767 Discussions
Intel graphic problem with FIFA 17
AAliK
Hello
I have a Intel Core i3 6100 with Intel HD 530 graphic unit.
After investigating and searching a lot about the problem I found that a wide range of Intel graphic unit have this problem. The problem is about FIFA 17.
In my case, FIFA loads very very difficult while OS start to hang up. In the game There are lighting process problems like flashing and the gameplay in most scenes is like zebra skin!!!(below in the video you can see)
Please please please! Do NOT ask common and ordinary questions like updating , driver , etc
I'm a Professional user and before contacting the support center I did all methods to solve the problem and checked the similar posts on the Internet.
I want to make you confident that:
  1. 1- All the HWs are healthy and work without any problem.
  2. 2- The OS is healthy and without malware and all the required runtimes are installed. In other words The System don't have lack of HW or SW and is completely OK.
  3. 3- The problem exists on every resolution and game setting.
  4. 4- The problem does not solve with the beta driver.
It should be noted that FIFA 16 and 15 runs without any problem and this problem is for FIFA 17 and FIFA 17 demo (both have the problem).
I'm not alone and There are users that are suffering from this bothering problem like:
  1. 1- /thread/107676 https://communities.intel.com/thread/107676
  2. 2- https://www.youtube.com/watch?v=QlEFFj_-zWw https://www.youtube.com/watch?v=QlEFFj_-zWw
  3. 3- https://www.youtube.com/watch?v=_IT39OGiu1w https://www.youtube.com/watch?v=_IT39OGiu1w
  4. 4- https://www.youtube.com/watch?v=ShEebMZuOdU https://www.youtube.com/watch?v=ShEebMZuOdU
  5. 5- http://www.notebookcheck.net/FIFA-17-Notebook-and-Desktop-Benchmarks.179319.0.html http://www.notebookcheck.net/FIFA-17-Notebook-and-Desktop-Benchmarks.179319.0.html
In the review article mentioned 2 times the Intel graphic problems.
Please see my video and above videos to see the problem.
Note: my friend with the exactly same specification (same MB, CPU,RAM) and a nVidia GPU does not face with these problems and bugs.
I think the only way to solve this problem is to release a new driver.
My video link: http://www.aparat.com/v/rzm2O http://www.aparat.com/v/rzm2O
System Specification:
Intel Core i3 6100
Asus Z170-A
2*4 GB DDR4 RAM
Samsung evo 850 SSD
Thank you a lot.
Hello AliKalhor,
Since you already tried our Beta driver I would need more information in regard to your system in order to address this issue in a different manner, so please proceed to fill out the following form , make sure to follow closely all the instructions on link, and once you have all the information requested post it here.
Amy.
AAliK
Hello
Did you watch my video?
Description: In above post
HW: 1-MB: Asus Z170-A
2- Graphic: Intel HD 530
3- no AMD or nVidia Graphic card
4- any kind of display(lg 25um65, samsung TV or Sony TV) I try a lot of displays.
EFP
RAM: 8GB DDR4 2400MHz
HDMI, Use SSD and HDD (the game has problem on both of them)
OS:Windows 10 pro ver 1607 build 14393.351
VBIOS: 1033
graphic driver: 15.4539(and all earlier driver)
single display
the problem exist in every resolution and setting
video was attached
AliKalhor, thank for the information.
Your video will definitely help to address this matter; however, for debugging purposes we need the information requested on this link . The reason why I am requesting this information is because you already tried the driver that addressed some issues with FIFA 17, but you still have an issue, so is very important forus to get all the information in regard to your case and start investigating.
Amy.
AAliK
Hello.
I will provide all the information you need but before that I want to ask a question. Why you think that the problem is only for me? It's a widespread problem for a wide range of users and related to Intel Driver not my PC!
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
In the original post I've provided detailed information
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%):X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Asus Motherboard (Z170-A)
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No just Intel HD 530
No
Make and model of any Displays that ...
We are aware that the are some issues with this game and the Intel® HD Graphics; however, most of them can be addressed with the Beta driver. We will take all your information into consideration for the review.
Thank you.
Amy.
We have just released a new driver version which is .4542, while we are still reviewing your case I am going to need from you to test this driver; so please give it a try and let me know how it goes.
Intel® HD Graphics version .4542; https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88345 Download Intel® Graphics Driver [15.45]
Amy.
AAliK
Hello
Big like for this beta driver.
All of the problem are solved except the problem of loading the game.
Still when I want to start the game My PC hangs and loading process takes a lot of time.
This beta driver is a huge improvement but there is one more thing to solve.
Thank you a lot
Thank you for that information.
I will add this to the investigation, I will keep you posted.
Amy.
AliKalhor,
For debugging purposes, could you please provide the DxDiag report with the driver .4542 installed?
Amy.
AAliK
Thank you for the report.
This will added to the investigation, I will update the thread as soon as I have more answers.
Amy.
AliKalhor,
Please try the following suggestions;
  • Clear Origin cache files, see here on how to do it; http://answers.ea.com/t5/Origin/How-do-I-clean-the-Origin-cache-files/td-p/4701923 How do I clean the Origin cache files? - Answer HQ
  • Test by using Compatibility mode. For this, go to FIFA 17 exe and right click on it, go to properties. Following that, click Compatibility tab, check the option "Compatibility Mode" and select Win7.
  • Re-install the game if issue persists.
Let me know how it goes.
Amy.
AliKalhor,
Were you able to follow the suggestion mentioned above?
Amy.
AAliK
Hello
Excuse me for delay.
I will do that and release the result
Keep me posted.
Amy.
AliKalhor, don't forget to keep me posted.
Amy.
ACons3
Hello there I recently purchased FIFA 17 full version for PC on my laptop.
Unfortunately there is an issue which does not allow me to play the game. The game proceeds until the loading screen with Marco Reus and its just stuck there forever. I have tried numerous things like repiaring the game via the right click option on Origini and my drivers according to device manager are up to date.
Below are my laptops specifications:
Windows 8.1 64 bit operating system, x-64 based processor
Processor: Intel (R) Core (TM) i5-4210U CPU@ 1.70 2.40 Ghz
Installed Memory RAM: 4..00 GB (3.89 GB USABLE)
Intel HD graphics family
Lenovo.
Please get back to me on how I can make the game work and what is the issue, what action needs to be taken.
Thank you
Alex94
Hello alex94,
Thank you for joining the thread.
For us to further assist you and to help you with the specific problem, please create a new thread, make sure to add all the details in regard to your system. This way the next agent will have a better look at your specific scenario, you can add this thread as a reference but I recommend creating a new thread in order to isolate your case.
Amy.
