23850 Discussions
Intel graphics command center
Leonid1
Я настраивал цветокорекцию на мониторе в программе intel
Но случайно получилось что изменил слишком сильно что ничего не вижу
Jean_Intel
Hello Leonid1,
Thank you for posting in the Intel communities. We would be more than glad to help you with your issue.
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
If it is possible, we would like to recommend using a second display, the color option only apply to the screen you select, and click the option "Restore to Original Colors" to eliminate the color profile you have created. This option is located on the Display> Color> Restore to Original Colors.
Jean O.
Jean_Intel
Hello Leonid1,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello Leonid1,
Best regards.
Jean O.
