23683 Discussions
Intel graphics control panel won't open
I am using a asus transformer t100taf, the graphics card I have is a Intel(R) HD Graphics. When I attempt to open the graphics control panel it show that its initializing then closes.
and its running on the windows 10 update.
Hello, dasfen:
Could you please let us know the driver version you are running? Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
Amy.
HInte
I have the exact problem with my intel nuc and all intel graphic drivers on Windows build 14393 (Aniversery Edition)! The Control Panel won't start after the installation! And I had the same problem on the very first Windows 10 RTM Release on the nuc as well - than you patched it (after months) and now the exact same thing! I am unable to change the resolution for my sharp-tv because only your control panel can do it (trough the desktop adjustment feature) - so I cant use my nuc 😞
whats going on - are you not teaming up with Microsoft?
Ive tested it with the latest drivers:
20.19.15.4474 (15.40.26)
and
20.19.15.4463 (15.40.25)
both had the same issue...
my nuc:
http://www.intel.de/content/www/de/de/nuc/nuc-kit-d54250wyk-board-d54250wyb.html Mini-PC: Intel® NUC-Kit D54250WYK
Hello:
Thank you for joining the Graphics Community.
Does the issue persist with previous versions? Is there any chance you can try one of the following versions? https://downloadcenter.intel.com/download/25951/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81495 Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen], https://downloadcenter.intel.com/download/25860/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81495 Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen], https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=81495 Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40] use this method for the installation http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 &...
Let me know your findings.
Amy.
HInte
the manual installation isn't working and older drivers wont work either! But the ultimate question is: what special registry framework uses the control panel? why in hell it wont start? the drivers are completely fresh installed (without any errors) and even the display driver uninstaller cant help... why?!
I had a similar behavior on a Surface Pro 4 but with manual installation I was able to install driver and open the Intel® HD Graphics control panel. You could try running the System File Checker tool, see here for the instructions https://support.microsoft.com/en-us/kb/929833 https://support.microsoft.com/en-us/kb/929833. You can also try fixing the registry by running system restore, see instructions below: http://www.tenforums.com/tutorials/4588-system-restore-windows-10-a.html http://www.tenforums.com/tutorials/4588-system-restore-windows-10-a.html.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
Hello:
I wanted to check on your thread; were you able to follow the suggestion mentioned above? Does the issue persist?
Amy.
