23781 Discussions
Intel hd 630
DFern14
Detail of my computer:
Motherboard: MSI Z270-A PRO
Memory: Corsair DDR4 3200MHz - 2X8GB ( Memory - Empty - Memory - Empty)
CPU: Intel i7-7700k LGA1151 (Intel hd 630)
OS: Windows 10 Enterprise x64
-Into WIndows
-I downloaded drivers of https://www.msi.com/Motherboard/support/Z270-A-PRO.html# down-driver https://www.msi.com/Motherboard/support/Z270-A-PRO.html# down-driver
-I installed the driver of the graphics (Intel hd 630)
-Video drivers not working properly
-I downloaded drivers of https://www.intel.la/content/www/xl/es/support/graphics-drivers/000005746.html https://www.intel.la/content/www/xl/es/support/graphics-drivers/000005746.html
(Example: In Photoshop, the colors blink - On YouTube sometimes the video becomes green screen)
DFern14
Intel(R) HD Graphics 630
Report Date: Friday, September 1, 2017
Report Time [hh:mm:ss]: 10:49:56 PM
Driver Version: 22.20.16.4771
Operating System: Windows* 10 Enterprise (10.0.15063)
Physical Memory: 16276 MB
Vendor ID: 8086
Device ID: 5912
Device Revision: 04
Video BIOS: 1046.0
Current Resolution: 3840 x 2160
Processor: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
Processor Speed: 4200 MHz
Processor Graphics in Use: Intel(R) HD Graphics 630
Shader Version: 5.1
OpenGL* Version: 4.5
OpenCL* Version: 2.1
Vulkan* Version: 1.0.38
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Display *
Display Type: Digital
Serial Number: HTPJ500007
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Device Type: DisplayPort
Maximum Image Size
Horizontal Size: 24.02 inches
Vertical Size: 13.78 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (70p Hz)
1024 x 768 (75p Hz)
1024 x 768 (60p Hz)
1152 x 864 (75p Hz)
1152 x 870 (75p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1280 x 1024 (75p Hz)
1280 x 1024 (60p Hz)
1440 x 900 (60p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
2560 x 1440 (60p Hz)
3840 x 2160 (60p Hz)
3840 x 2160 (30p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C 2D 4D 0C 45 57 51 30
15 1B 01 04 B5 3D 23 78 3A 5F B1 A2 57 4F A2 28
0F 50 54 BF EF 80 71 4F 81 00 81 C0 81 80 A9 C0
B3 00 95 00 01 01 4D D0 00 A0 F0 70 3E 80 30 20
35 00 5F 59 21 00 00 1A 00 00 00 FD 00 38 4B 1E
87 3C 00 0A 20 20 20 20 20 20 00 00 00 FC 00 55
32 38 45 35 39 30 0A 20 20 20 20 20 00 00 00 FF
00 48 54 50 4A 35 30 30 30 30 37 0A 20 20 01 70
02 03 0E F0 41 10 23 09 07 07 83 01 00 00 02 3A
80 18 71 38 2D 40 58 2C 45 00 5F 59 21 00 00 1E
56 5E 00 A0 A0 A0 29 50 30 20 35 00 5F 59 21 00
00 1A 04 74 00 30 F2 70 5A 80 B0 58 8A 00 5F 59
21 00 00 1E 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 52
* Other names and brands are the property of their respective owners.
Hello Danicof,
Thank you for joining the Graphics community. I am sorry to hear you are having issues with the graphics drivers.
I would like to gather more information regarding this behavior, please see below;
  • When did the issue start?
  • Does it only happen with the two apps(Photoshop and YouTube) mentioned?
  • What are the Intel® HD Graphics driver versions you have tested? Please add the number of the versions.
  • Does the behavior happen while using a different video port?
Thank you.
Amy C.
DFern14
The issue started from the beginning.
No, this problems happens with various apps. For example, (Substance painter 2) is impossible utilize.
I tested Intel® HD graphics driver versions (Inte® hd graphics 630):
21.20.16.4565 - 2017-04-27 (MSI)
5.45.19.4678 - 2017-05-30 (Intel)
15.46.05.4771 - 2017-08-23 (Intel)
Yes, the behavior happen while using dvi port and displayport.
(The motherboard hasn't hdmi port)
Note: My monitor is Samsung 4k
Thank you for your answers.
Could you please list the name of the apps that you are having issues with? Also provide a brief explanation of the specific issue that you see in those apps, if possible attach screenshots of the issue. I am aware that in Photoshop, the colors blink and that using YouTube sometimes the video becomes green screen, so please let me know the behavior with the other apps.
In the meantime, I would like to request a test with some older drivers in order to cross out a possible issue with drivers, please see below.
Use this method for the installation: https://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows...
Amy C.
/thread/117642 Danicof,
If you need further assistance let us know.
Amy C.
