23774 Discussions
Intel hd graphics 3000 dedicated graphics memory
msten1
Hi all
I have a board with 64MB of dedicated graphics memory.
Is possible to increase the memory to 128mb?
thanks
msten1
up
Allan_J_Intel1
I understand you would like to increase video memory on your system.
The Intel® HD Graphics 3000 supports up to 1.7GB of shared video memory. This is possible only if you can find settings at BIOS level.
You need to check with your motherboard manufacturer for any option at BIOS through video configuration to enable dynamic video memory or share memory settings.
See below for more information:
http://www.intel.com/support/graphics/sb/CS-029090.htm http://www.intel.com/support/graphics/sb/CS-029090.htm
Allan.
msten1
thanks, but has no option to increase the memory at bios
PVlad2
If you are on a laptop it's not very likely that you have a setting for specifying the memory to allocate for the integrated graphics. This feature is usually available on desktops, but rarely on laptops. If you need to increase the video memory in order to run a given game I suggest you look for a patch or a configuration setting that lets this game run on Intel HD Graphics instead. The following articles contain some other tips and tricks that will help you get the maximum performance out of your Intel HD Graphics:
http://www.pvladov.com/2013/01/improve-intel-hd-graphics-performance.html 4 Ways to Improve Intel HD Graphics Performance
http://www.pvladov.com/2013/10/increase-intel-hd-graphics-dedicated-video-memory.html How to Increase Intel HD Graphics "Dedicated" Video Memory
msten1
it is possible to share memory ram with the video card?
Allan_J_Intel1
Video cards have dedicated memory, it won't shared memory ram.
Allan.
mhero1
you could try to fool game by changing the amount of memory that game has scaned like i play gta 4 medium and i changed to 1760 maximum of amount that my hd have.
try that i can play games that i couldnt before o and make sure to speed proccesor read instructions
1.start up run and write in %temp% delete everything if something that cant be deleted press skip
2.go to advanced system settings then advanced press performence advanced choose programs then look at virtual memory press change and put in those 2 windows 16416 if you can it will speed up little bit i have 4.34 ghz but i had 2.2 im on laptop so its 4.34 is very high on laptop like mine. and run all 4 cores if you have only 2 run them not only one if i wouldnt i would have 2.34ghz but my laptop have 4 cores and now i have 4.34ghz so be sure to run them. look how to do it im on windows 10 i dont find the option where so yea.
EDIT:i play gta 4 medium at 75 to 80 fps maybe doing it high but i want it run more then 60 fps but i can play 30fps but i modding so yea i think i can play gta 5 low i will try that later 30 fps would be awesome couse intel hd 3000 with intel i3 2nd gen isnt best good thing i have 4 cores!:EDIT
