23587 Discussions
Intel i5 6400 HD Graphics 530
ААлес
Good day! There is a system m.board H110M MSI, processor Intel i5 6400 with integrated HD Graphics 530, the system should be available about 3 GIG. installed RAM, but this integrated adapter selects RAM 1GIG. how to limit the amount of RAM used on this video card?
Hello IWINSTONI ,
Thank you for contacting the Intel community.
In order for you to increase or decrease the video ram you will need to do it from your system BIOS, at this point, you will need to contact your motherboard manufacturer for them to guide you how to set that up in the BIOS.
The feature that sets the amount of memory that is used for video is called Intel(R) Dynamic Video Memory Technology and this will make the graphics controller only to use the amount of RAM memory that it requires to run the different applications or software's.
Note: Only if the computer BIOS allows you to change the video memory. If you are not able to find any option at BIOS level, then this is locked by your computer manufacturer.
Ivan.
