20692 Discussions
Intel i5 6600 530 graphics flicker w/ B150M-D3H
I am using a 6600 processor via the B150M-D3H for my graphics, this is a very common bundle, so I imagine others will have this issue too.
Windows 7 x64, Kingston HyperX Fury DDR4 2133MHz
As the B150M-D3H only supports my second monitors native resolution of 2560x1600 @60p Hz via HDMI I am forced to use this.
My first monitor is 1600x900 via VGA.
When I first attached the second monitor the screen blanked out and told me I was not achieving the required signal strength.
I went out and bought a "high speed" HDMI 1.4 cable, but despite it being sold as this I was later told it wasn't, (when I bought the non working cable back) I then got a HDMI 2.0 4K capable cable.
The HDMI 2.0 cable works for the most part. The screen doesn't black out and I don't have thousands of red flashing pixels as I did with other cables.
However I still have very hard to see, but distracting little flashing lines that seem to occur on the edges of boxes that are Aero transparent. They are about 1-2cm long, and are white as far as I can tell.
I also fail http://www.testufo.com/# test=frameskipping this test.
I feel very strongly that the issue is cable related.
I used to run the monitor fine on my old AMD motherboard via DVI-D at full 1600, but the B150M-D3H runs it at 1080.
I flashed the BIOS to the most recent F6.
I installed the lastest driver https://downloadcenter.intel.com/download/25484/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Graphics Driver for Windows® 7/8.1/10* [15.40]. (before doing this I had a couple of random display adapter crashes)
I installed the latest monitor drivers for both monitors.
I am wondering if an HDMI to DVI-D cable adapter for the monitor end will make a difference, but I don't see why it would, and I'm not sure of HDMI 2.0 compatibility.
Any ideas?
I thought I would give a new cable a try before leaving my computer in the shop again and that has fixed it.
The Dynamix 4K cable is simply not good enough for this budget setup. It is however fine when using a good graphics card.
Bought an Accell ProUltra Supreme cable (good quality, but not ridiculously expensive) and flashing lines are gone.
However there were issues with graphics crashes and flashing screens.
More on this:
I installed the beta driver recommended earlier in this thread before I took it to the shop. The shop installed Intel driver update to update the driver, which installed a really old one. Windows update then updated to a newer one, which is still older than the beta. The crashes occurred until I reinstalled the beta driver. Now all is well.
So, from this I must deduce that Intel 530 graphics are incredibly fussy about the HDMI cable, and that only high quality HDMI 2.0 cables will work with large (in this case 30") high resolution monitors.
The latest beta driver is also required for trouble free operation.
The lower quality cable was able to drive the monitor fine on the same MB using an Asus 7770.
Hello Gareth:
The fact that you purchased a HDMI 2.0 4K capable cable is actually good, because it is better to have a high quality cable.
In regard to the driver, there is a newer version for it, let me give you the link so you can install it:
https://downloadcenter.intel.com/download/26078/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- https://downloadcenter.intel.com/download/26078/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-
That is version 15.40.25.4463 and the one you have is 15.40.10.4300.
To make sure to have the latest BIOS version for the board and the drivers installed for both monitors also is something that we recommend to do, so, at this point pretty much you tried all the troubleshoot steps that are recommended.
To get a HDMI to DVI-D cable adapter might help, the thing about display adapters is that some of them work pretty good, and some of them are not compatible, so, the best way to find that out will be by using it, that is why we advice to use a straight HDMI cable.
So, please try the driver above, and then let us know the results of doing that.
Alberto
Hello Gareth:
Sorry to hear that it is not working.
How are you connecting the monitors, are you using 2 different ports with straight cables for each monitor or you are using a display adapter or converter?
Did you install the graphics driver for the board?
http://www.gigabyte.com/products/product-page.aspx?pid=5491# dl http://www.gigabyte.com/products/product-page.aspx?pid=5491# dl
Could you please provide the model of both monitors and a screenshot in order for us to verify how the screen looks like?
What is the model of the AMD motherboard you used to have?
Alberto
I installed all the drivers from that link after I did the initial install.
I have just done a "repair" on the chipset drivers and reinstalled the gigabyte display driver, note the version linked above is newer, but I decided to install the one from the gigabyte website again as the newer one didn't solve the issue.
Primary monitor is HP 2011X vga to vga, secondary monitor is HP Z30i hdmi 2.0 to hdmi 2.0.
Even if I disconnect the 2011X and have only the Z30i as the primary, the issue still occurs.
https://drive.google.com/file/d/0B2sWKNJasGCHb0hHT2g5Z0xFanc/view?usp=sharing Video showing the issue
After all of this I am starting to believe the CPU may be faulty.
I have had a number of unexpected shutdowns, that are possibly related.
Log Name: System
Source: EventLog
Date: 25/06/16 7:05:56 AM
Event ID: 6008
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Gareth-PC
Description:
The previous system shutdown at 7:00:11 AM on ‎6/‎25/‎2016 was unexpected.
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event">
6008
2
0
0x80000000000000
12776
System
Gareth-PC
7:00:11 AM
‎6/‎25/‎2016
73804
E007060006001900070000000B008800E007060005001800130000000B008800600900003C000000010000006009000000000000B00400000100000000000000
Log Name: System
Source: EventLog
Date: 10/06/16 6:47:55 PM
Event ID: 6008
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Gareth-PC
Description:
The previous system shutdown at 6:45:13 PM on ‎6/‎10/‎2016 was unexpected.
Event Xml:
6008
2
0
0x80000000000000
6520
System
Gareth-PC
6:45:13 PM
‎6/‎10/‎2016
1801
E007060005000A0012002D000D001D02E007060005000A0006002D000D001D02600900003C000000010000006009000000000000B00400000100000000000000
Log Name: System
Source: EventLog
Date: 10/06/16 6:15:20 PM
Event ID: 6008
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Gareth-PC
Description:
The previous system shutdown at 6:12:10 PM on ‎6/‎10/‎2016 was unexpected.
Event Xml:
6008
2
0
0x80000000000000
6395
System
Gareth-PC
6:12:10 PM
‎6/‎10/‎2016
1741
E007060005000A0012000C000A00F202E007060005000A0006000C000A00F202600900003C000000010000006009000000000000B00400000100000000000000
Log Name: System
Source: EventLog
Date: 10/06/16 5:43:19 PM
Event ID: 6008
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Gareth-PC
Description:
The previous system shutdown at 5:38:04 PM on ‎6/‎10/‎2016 was unexpected.
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event<span...
Hello Gareth:
We are going to try to replicate this issue, we just need for you to provide some information about your system, some of that information was already provided, but we need those reports to be able to replicate it:
We need a report from the Intel® HD Graphics control panel, once you open that, choose "options and support", then choose "information center", and then choose where it says "file" at the bottom, you will get a text file, please attach it to the thread.
Besides that information, please install the SSU tool (System Support Utility):
You will be able to download it on the following link:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Once you do that, the tool will allow you to save the information as a file, so, once you save it, please attach it to this thread.
And finally we need for you to please fill the information on the following chart:
CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issue Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>Always (100%):
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):</span>Hardware (HW)Brand and Model of the system. Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too? Make and model of any Displays that are used to see the issue (see note2 below).  LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in) How much memory [RAM] in the system (see note2 below). <span style="border: none windowtext 1.0pt; padding: 0in; color: # 3D3D3D; font-size: 10.0pt; font-family: aria...
CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issueA 2K monitor exhibits flickering line effects when using an i5 6600's onboard 530 Graphics via HDMI 2.0 cable even though supported. Effect is present in both single and dual monitor modes on the 2K monitor only.Please place an X to the right of the option showing how often you see this issue using specific steps.Always 100% occurance, but not always visible (i.e. it's a white flicker)Hardware (HW)Brand and Model of the system.Gigabyte B150M-D3H Motherboard, i5 6600 CPU, Kingston HyperX Fury 2x8GB DDR4 2133MHz RAM, HP Z30i 2560x1600 2K monitor, HDMI 2.0 4K male to male cableHybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?Effect is present when using onboard graphics only. When using the same system and an Nvidia Quadro 400 video card output via DVI-D the effect is not present. With the card installed, but onboard graphics are set to enabled via BIOS, then onboard outputs are used the effect is still present.Make and model of any Displays that are used to see the issue  HP Z30i EFPHow much memory [RAM] in the system 16GBProvide any other hardware needed to replicate the issue.
Dynamix C-HDMI20-1H 1.5m HDMI High Speed (v2.0) with ethernet-Ultra 4K cab...
Hello Gareth:
Thank you very much for that information, it is very useful for us to replicate the case, we are will try to get the same hardware configuration that you have.
As soon as we get the results I will provide all the details on this thread.
Alberto
Hello Gareth:
I was checking the reports you gave us and I see that for Intel® HD graphics 530 you are using driver version: 20.19.15.4364 and actually we have a new driver, please try to install it and let me know the results:
https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
Once you do that, use just the HP Z30i EFP monitor and let me know the results.
Alberto
No, this has not fixed it.
https://drive.google.com/file/d/0B2sWKNJasGCHaTZzS0lKYlhwRWM/view?usp=sharing VID_20160701_135809.3gp - Google Drive
I was not able to see it much in the valid box this time, but it is noticebale on the task bar.
Also possibly of note: PSU is Cooler Master Elite Power 400W RS-400-PSAP-J3
Hello Gareth:
Thank you very much for that information.
Since the driver did not work, we will try some more tests in order to try to find the proper solution for this problem.
As soon as we get the results, I will post it on this thread.
Alberto
Hello Gareth_O:
I just wanted to let you know that we were not able to replicate the issue, using an Intel® NUC and 2560x1440 monitor via HDMI. With driver version: 15.40.25.4463.
By case analysis, this could be a hardware issue.
Potential causes:
Defective HDMI port.
Faulty CPU.
Issue with 1 memory stick.
VBIOS bug.
So, the next thing to do in this case, will be to get in contact with Gigabyte directly, so they can validate your system configuration and replicate the issue for you using the same exact components.
Alberto
My concern is exactly that, that I do have faulty hardware, and that the warranty will expire before I can find the cause of the issue.
I have tried running on just 1 stick or RAM, the issue still occurs regardless of which stick or sticks are used. As I have the DDR4 MB I have no more RAM I can try. But it seems that RAM is unlikely to be the issue.
I don't think gigabyte will be much help if the CPU is faulty, but concede that a defective HDMI port could well be the issue.
Is there a way I can definitively rule out the CPU as being the cause? I don't want to be running on what could possibly be a faulty CPU.
I will contact gigabyte, but until the CPU is ruled out the ball is still in Intel's court.
Hello Gareth_O:
Yes, we understand your concern and we will try to help you as much as we can.
And you are right, it seems to be very unlikely for the RAM to be defective, and it is very hard to tell for sure if the problem is the HDMI port on the board or the processor.
That is why, since you do have 3 years of warranty on the processor, and the option of testing the board with a different processor is not available, we can always replace it for you.
In order to do that, please get in contact directly with us through chat, email, online support or phone support, here is the link to do that, you just need to select the type of product you are interested in replacing and you will get those options:
http://www.intel.com/content/www/us/en/support/contact-support.html# @12 http://www.intel.com/content/www/us/en/support/contact-support.html# @12
Alberto
Thank you, that is good to know. I am still waiting on a reply from Gigabyte. I will see what the can do before looking into the processor further.
On a side note, since signing up for this forum I have had a couple of emails from mailto:Not_A_Valid_Email_Address@intel.com Not_A_Valid_Email_Address@intel.com like this:
Order Number: 7501962489
Order Date: 2016-Jul-05
Product(s) Intel is sending to you OR product(s) you are returning to Intel:
(Note: Product information is based on substitute part availability. Actual part(s) may differ.)
Row No : 1
Part No : E97378-001-FXC
Product : DHA-A FAN HEATSINK (FOXCONN)
Is this something that was initiated by you or have these come to me by mistake?
Hello Gareth_O:
Sure, perfect, after you get the reply from Gigabyte, if a replacement of the processor is needed, just get in contact with us using the link I gave you before.
And yes, that was a mistake, let me apologize for that, please disregard that email.
Thank you.
Alberto
I have received a response from Gigabyte.
They asked me to try using the same set up, but use a video card for the HDMI out to rule out the monitor and the cable.
I used an Asus 7770 via HDMI and there was no sign of the issue.
If the cable and monitor are fine (which they are) Gigabyte says it must be an issue with either the HDMI port on the motherboard, or the CPU.
My supplier said they will first try a new motherboard, and if that doesn't work, a new CPU.
I will post the results.
Currently the issue looks like this (before taking to supplier)
https://drive.google.com/file/d/0B2sWKNJasGCHejEzbGpLYjZXdHM/view?usp=sharing VID_20160714_091706.3gp - Google Drive
Hello Gareth_O:
Perfect, if by any chance there is a problem with the processor, you do have 3 years of warranty on it, from the date of purchased, and we can always replace it for you.
If you are interested in the replacement, please get in contact directly with us through chat, email, online support or phone support, here is the link to do that, you just need to select processors and you will get those options:
Alberto
Hello Gareth_O:
I just wanted to check if the information posted previously on this thread was useful for you?
Any further assistance, please do not hesitate in contact us again.
Alberto
