23750 Discussions
Intel integrated graphics along with GPU..?
Lincon
Hello everyone,,
I was wondering if there is any way under windows, to use the integrated graphics of my 9700K along with my RTX 2080. I play competitive games @ 1080p on a 240Hz monitor and I need every last fps I can squeeze out of my machine. Can I make these two work together somehow?
AlHill
Only if your motherboard BIOS supports both integrated graphics and your RTX to be used concurrently. Most do not.
Doc
n_scott_pearson
Adding to the explanation... Most BIOS, when they detect that an add-in graphics card is present, will completely disable the on-chip graphics subsystem. Some BIOS support a parameter that allows you to have the on-chip graphics subsystem remain enabled regardless of whether or not an add-in card is present. Look in your BIOS for such a parameter. Better, just ask your motherboard vendor.
Hope this helps,
