23461 Discussions
Intel vga driver 101.8059,LCD display is whitish
neilzhang
The LCD screen displayed a whitish color when turned on for the first time
S0I3 will also reproduce
Disabling the "Intel Graphics Device" in the Device Manager will restore normal functionality;
Installing the 101.8629 driver still fails;
However, we are currently testing by uninstalling version 101.8509 before installing version 101.8629
Could you please confirm whether the 101.8509 driver causes unknown errors in certain data related to correcting the real-world colors in Windows? Please assist in resoPHOTO.jpglving this issue
Tharun_Intel
Hello neilzhang,
I hope you are doing great.
Thank you for reaching out to us on the Intel Community — we truly appreciate you taking the time to post, and we're glad you did!
We completely understand how frustrating and disruptive a display issue can be, and we want to assure you that you are in exactly the right place. Our team is fully committed to helping you get this resolved as quickly as possible.
To help us investigate this thoroughly, could you please share the following details?
1. Driver Version(s) Causing the Issue Which Intel Graphics driver version(s) have you noticed triggering the whitish display? If you've tested multiple versions, please share which ones were affected.
2. When Did This Start? Do you recall approximately when you first began experiencing this issue?
3. Any Recent Changes? Were there any recent software updates, driver installations, hardware changes, or new applications added around the time the issue first appeared?
4. Hibernate / Shutdown & Power-On Behavior Does the whitish display occur when waking the system from hibernate or sleep, or after a full shutdown and power-on? Or does it happen during normal active use? Understanding the exact trigger will help us identify the cause much faster.
5. Power Connection State Does the issue occur when your system is plugged into AC power, running on battery, or in both cases? Display behavior can sometimes differ based on the power source due to graphics power management settings.
6. HDR Support & Status Does your display support HDR (High Dynamic Range)? If yes, is HDR currently enabled in your Windows Display Settings? (You can check this by going to: Settings → System → Display → HDR.) Certain HDR configurations can sometimes cause washed-out or whitish display appearances.
7. Intel SSU Log Could you please run the Intel System Support Utility (SSU) and attach the generated log to your reply? This gives us a detailed snapshot of your system configuration and helps us diagnose the issue significantly faster. 👉 Download Intel SSU here
A Quick Note on What You've Observed:
Since disabling the Intel Graphics driver appears to resolve the issue, this is a strong indication that there may be a compatibility conflict between the Intel Graphics driver and your OEM (manufacturer-installed) drivers. OEM drivers are often customized for specific hardware configurations, and installing a generic Intel driver alongside them can sometimes cause conflicts — including display anomalies like the one you're experiencing.
You can read more about Intel and OEM driver compatibility here: Intel Graphics Driver & OEM Compatibility
Once you share the details above, we will dive right in and keep you updated every step of the way. You're in great hands, and we're committed to seeing this through with you!
Looking forward to hearing from you.
Tharun
Tharun_Intel
Hello  neilzhang,
I wanted to kindly follow up on my previous email regarding your open thread. I wanted to check in to see if you have had the opportunity to review it and whether you are able to provide the requested information at your earliest convenience.
Your response will allow us to move forward promptly and ensure we are able to assist you in the best way possible.
Should you have any questions or require any clarification, please do not hesitate to reach out — we are happy to help.
Thank you for your time, and we look forward to hearing from you soon.
Tharun
neilzhang
Sorry for the late reply!
The responses to the questions are as follows:
  1. NG Driver: 32.0.101.8509, upgrading from the original driver to 32.0.101.8629 is still NG, but OK after uninstalling the Intel VGA driver.
  2. After registration, it goes NG every time it wakes from sleep.
  3. No software updates have been made.
  4. Currently, the NG status cannot be restored regardless of doing S3, S4, or S5.
  5. Whether AC is connected or not, the current status is NG.
  6. Enabling & disabling HDR shows the over-white issue consistently.
  7. Please see the attachment in the attachment.
VivekS_Intel
Hello neilzhang,
Thank you for the detailed update and for sharing the requested information.
Intel has recently released a newer graphics driver, Version 32.0.101.8724 (Latest). To ensure the best performance and to clear any potential conflicts, we recommend performing a clean installation using DDU of this version:
Additionally, we strongly suggest visiting the MSI OEM support page to install all available drivers specifically validated for your hardware. We recommend testing the OEM graphics drivers as well in case the generic drivers continue to throw errors, as these often include critical system-specific fixes and display tuning that can resolve anomalies after sleep/wake cycles:
Please let us know the status of the issue after applying these updates. We look forward to your feedback.
VivekS
Manas_Intel
Hello neilzhang,
Thank you for your continued efforts and for the detailed observations you’ve shared so far.
As a next step, we recommend performing another clean driver installation using DDU to fully remove any residual components from previous versions. After that, please install the latest Intel® Graphics Driver version 32.0.101.8735, released on April 21, 2026. This version includes recent fixes and optimizations that may help address the display behavior you’re experiencing from the link here:
Intel® Arc™ Graphics - Windows*
Additionally, we still encourage checking the MSI OEM support page for your system and testing the graphics drivers available there. OEM-provided drivers are often customized for the platform and may include specific tuning or fixes for panel behavior, especially in scenarios involving sleep states like S0I3.
If needed, we can also provide remote assistance to help perform these steps and further investigate the issue.
Once you’ve completed these steps, please let us know if the issue persists or if you notice any changes. Your feedback will help us determine the next course of action.
Manas Sharma
neilzhang
Thank you very much to the Intel team for providing the new driver. We are currently continuing to replicate it and have not yet replicated it
I have another question to ask:
How does Intel GPU transfer Windows color ICC configuration file data to the display? What is the process and can you provide a detailed explanation at the bottom? Thank you!
Ramgound_Intel
Hello neilzhang,
Thank you for your update, and we’re glad to hear you are continuing the replication process.
We also acknowledge your additional question regarding how Intel GPU handles Windows ICC color configuration data transfer to the display. This is a detailed technical topic, and we will need some time to provide you with an accurate and comprehensive explanation.
We will review this internally and get back to you with a detailed response shortly.
Thank you for your patience and understanding.
Ramgound
Manas_Intel
Hello neilzhang,
Thank you for your patience while we reviewed your question in more detail.
The Intel® GPU does not transfer the ICC profile to the display. In Microsoft Windows, the ICC profile is processed by the Windows Color System (WCS) to generate color corrections. These corrections are applied inside the GPU using its color pipeline (matrix and LUT), and the GPU then sends already corrected pixel data to the display over HDMI/DisplayPort.
For more details, please refer to Microsoft’s documentation:
https://learn.microsoft.com/en-us/windows/win32/wcs/display-calibration-mhc
Please feel free to reach out if you have any further questions, we’re happy to assist.
Manas Sharma
Manas_Intel
Hello @neilzhang ,
Manas Sharma
Manas_Intel
Hello @neilzhang,
I just wanted to follow up on your query and check if the information we shared was helpful.
If you have any additional questions or if there’s anything you’d like us to clarify further regarding ICC profiles or GPU color processing, please don’t hesitate to let us know, we’ll be glad to assist.
Manas Sharma
Manas_Intel
Hello @neilzhang,
I hope you’re doing well.
I just wanted to follow up on my previous response regarding how ICC profiles are handled. I hope the explanation and the Microsoft documentation were helpful in clarifying your question.
If you’ve had a chance to review the information and have any further questions, or if something isn’t quite clear, please don’t hesitate to let me know. I’d be more than happy to assist further.
Looking forward to your thoughts.
Manas Sharma
