23802 Discussions
Intel video acceleration error - unknown libva error :: Fedora 42 latest intel/media-driver from git
nrrv
[*] System info
Linux desk 6.16.0-200.fc42.x86_64 #1 SMP PREEMPT_DYNAMIC Fri Aug 8 15:17:26 UTC 2025 x86_64 GNU/Linux
NAME="Fedora Linux"
VERSION="42 (Workstation Edition)"
RELEASE_TYPE=stable
ID=fedora
VERSION_ID=42
VERSION_CODENAME=""
PLATFORM_ID="platform:f42"
PRETTY_NAME="Fedora Linux 42 (Workstation Edition)"
ANSI_COLOR="0;38;2;60;110;180"
LOGO=fedora-logo-icon
CPE_NAME="cpe:/o:fedoraproject:fedora:42"
DEFAULT_HOSTNAME="fedora"
HOME_URL="https://fedoraproject.org/"
DOCUMENTATION_URL="https://docs.fedoraproject.org/en-US/fedora/f42/"
SUPPORT_URL="https://ask.fedoraproject.org/"
BUG_REPORT_URL="https://bugzilla.redhat.com/"
REDHAT_BUGZILLA_PRODUCT="Fedora"
REDHAT_BUGZILLA_PRODUCT_VERSION=42
REDHAT_SUPPORT_PRODUCT="Fedora"
REDHAT_SUPPORT_PRODUCT_VERSION=42
SUPPORT_END=2026-05-13
VARIANT="Workstation Edition"
VARIANT_ID=workstation
[*] CPU info
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 16
On-line CPU(s) list: 0-15
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 7 5700X3D 8-Core Processor
CPU family: 25
Model: 33
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
Stepping: 2
Frequency boost: enabled
CPU(s) scaling MHz: 78%
CPU max MHz: 4151.3838
CPU min MHz: 575.1920
BogoMIPS: 5988.67
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl xtopology nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local user_shstk clzero irperf xsaveerptr rdpru wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif v_spec_ctrl umip pku ospke vaes vpclmulqdq rdpid overflow_recov succor smca fsrm debug_swap
Virtualization: AMD-V
L1d cache: 256 KiB (8 instances)
L1i cache: 256 KiB (8 instances)
L2 cache: 4 MiB (8 instances)
L3 cache: 96 MiB (1 instance)
NUMA node(s): 1
NUMA node0 CPU(s): 0-15
Vulnerability Gather data sampling: Not affected
Vulnerability Ghostwrite: Not affected
Vulnerability Indirect target selection: Not affected
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Mmio stale data: Not affected
Vulnerability Old microcode: Not affected
Vulnerability Reg file data sampling: Not affected
Vulnerability Retbleed: Not affected
Vulnerability Spec rstack overflow: Mitigation; Safe RET
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2: Mitigation; Retpolines; IBPB conditional; IBRS_FW; STIBP always-on; RSB filling; PBRSB-eIBRS Not affected; BHI Not affected
Vulnerability Srbds: Not affected
Vulnerability Tsa: Mitigation; Clear CPU buffers
Vulnerability Tsx async abort: Not affected
[*] PCI devices (GPU)
0b:00.0 VGA compatible controller [0300]: Intel Corporation Battlemage G21 [Arc B580] [8086:e20b]
Subsystem: ASRock Incorporation Device [1849:6021]
Kernel driver in use: xe
Kernel modules: xe
0c:00.0 Audio device [0403]: Intel Corporation Device [8086:e2f7]
[*] Loaded Intel GPU kernel modules
[*] libva versions
libva info: Open new log file /tmp/libva.log.200200.thd-0x000094ae for the thread 0x000094ae
libva info: LIBVA_TRACE is on, save log into /tmp/libva.log.200200.thd-0x000094ae
libva info: VA-API version 1.23.0
libva info: User environment variable requested driver 'iHD'
libva info: Trying to open /usr/local/lib/dri/iHD_drv_video.so
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
Trying display: wayland
[*] Installed libva packages
libva-2.22.0-4.fc42.x86_64
libva-intel-media-driver-25.2.6-1.fc42.x86_64
libva-2.22.0-4.fc42.i686
libva-intel-driver-2.4.1^20241027gitd30e013-1.fc42.x86_64
libva-utils-2.22.0-4.fc42.x86_64
libva-devel-2.22.0-4.fc42.x86_64
libva-vdpau-driver-0.7.4-208.20211013.fc42.x86_64
[*] Environment variables
PKG_CONFIG_PATH=/usr/local/lib64/pkgconfig:/usr/local/lib64/pkgconfig
LIBVA_DRIVER_NAME=iHD
LIBVA_TRACE=/tmp/libva.log
LIBVA_MESSAGING_LEVEL=2
LD_LIBRARY_PATH=/usr/local/lib64:/usr/local/lib64
LIBVA_DRIVERS_PATH=/usr/local/lib/dri
OLDPWD=/usr/local/src/libva
[*] dmesg (GPU related)
[*] VA-API driver files
/usr/lib64/dri/iHD_drv_video.so
/usr/lib64/dri/i965_drv_video.so
/usr/lib64/dri/s3g_drv_video.so
/usr/lib64/dri/vdpau_drv_video.so
/usr/lib64/dri/d3d12_drv_video.so
/usr/lib64/dri/nouveau_drv_video.so
/usr/lib64/dri/r600_drv_video.so
/usr/lib64/dri/radeonsi_drv_video.so
/usr/lib64/dri/virtio_gpu_drv_video.so
[*] Display server info
XDG_SESSION_TYPE=wayland
WAYLAND_DISPLAY=wayland-0
DISPLAY=:0
% cat /tmp/libva.log.200200.thd-0x000094ae
[52408.055162][ctx none]==========va_TraceInitialize
[52408.055169][ctx none]=========vaInitialize ret = VA_STATUS_ERROR_UNKNOWN, unknown libva error
[52408.055171][ctx none]==========va_TraceTerminate
[52408.055177][ctx none]=========vaTerminate ret = VA_STATUS_SUCCESS, success (no error)
nrrv
So, I got it working. I needed:
To enable Resize Bar in my UEFI
install the intel-media-driver from the git hub at - commit e46f78c35dfd11d7d95addf7b0b68685a2010fae (HEAD, tag: intel-media-25.3.2)
I installed with the prefix /usr but that may be a coincidence
It works. The requirement of resize bar was hard to find.
nrrv
I am willing to provide any information, or run any tests that would be helpful.
Gaming and rendering work well, but hardware acceleration is an issue.
Cheers,
Nicolas Vaagen
ps: I used this bash script to generate the report:
cat gather_arc_b580_inyo.sh
#!/bin/bash
# Script to gather system and VA-API info for Intel Arc B580
OUTPUT_DIR="$HOME/arc_b580_report"
mkdir -p "$OUTPUT_DIR"
echo "Gathering information into $OUTPUT_DIR..."
# 1. System info
echo "[*] System info" | tee "$OUTPUT_DIR/report.txt"
uname -a | tee -a "$OUTPUT_DIR/report.txt"
cat /etc/os-release | tee -a "$OUTPUT_DIR/report.txt"
# 2. CPU and GPU info
echo -e "\n[*] CPU info" | tee -a "$OUTPUT_DIR/report.txt"
lscpu | tee -a "$OUTPUT_DIR/report.txt"
echo -e "\n[*] PCI devices (GPU)" | tee -a "$OUTPUT_DIR/report.txt"
lspci -nnk | grep -i -A4 'VGA\|3D' | tee -a "$OUTPUT_DIR/report.txt"
# 3. Loaded kernel modules
echo -e "\n[*] Loaded Intel GPU kernel modules" | tee -a "$OUTPUT_DIR/report.txt"
lsmod | grep i915 | tee -a "$OUTPUT_DIR/report.txt"
# 4. libva versions
echo -e "\n[*] libva versions" | tee -a "$OUTPUT_DIR/report.txt"
vainfo 2>&1 | tee -a "$OUTPUT_DIR/report.txt"
# 5. Installed libva packages (Fedora)
echo -e "\n[*] Installed libva packages" | tee -a "$OUTPUT_DIR/report.txt"
rpm -qa | grep -iE 'libva|intel-media-driver' | tee -a "$OUTPUT_DIR/report.txt"
# 6. Environment variables
echo -e "\n[*] Environment variables" | tee -a "$OUTPUT_DIR/report.txt"
env | grep -iE 'LD_LIBRARY_PATH|LIBVA|PKG_CONFIG_PATH' | tee -a "$OUTPUT_DIR/report.txt"
# 7. Dmesg GPU messages
echo -e "\n[*] dmesg (GPU related)" | tee -a "$OUTPUT_DIR/report.txt"
dmesg | grep -i -E 'i915|intel|arc' | tee -a "$OUTPUT_DIR/report.txt"
# 8. Check driver files
echo -e "\n[*] VA-API driver files" | tee -a "$OUTPUT_DIR/report.txt"
find /usr/local/lib64/dri /usr/lib64/dri 2>/dev/null | grep '_drv_video.so' | tee -a "$OUTPUT_DIR/report.txt"
# 9. X11 / Wayland info
echo -e "\n[*] Display server info" | tee -a "$OUTPUT_DIR/report.txt"
echo "XDG_SESSION_TYPE=$XDG_SESSION_TYPE" | tee -a "$OUTPUT_DIR/report.txt"
echo "WAYLAND_DISPLAY=$WAYLAND_DISPLAY" | tee -a "$OUTPUT_DIR/report.txt"
echo "DISPLAY=$DISPLAY" | tee -a "$OUTPUT_DIR/report.txt"
echo -e "\n[*] Finished gathering info."
echo "All logs and info are saved in $OUTPUT_DIR"
nrrv
So I have progress. Well, in identifying the issue.
from log:
Process 32831 (vainfo) of user 1000 dumped core.
Module /usr/bin/vainfo from rpm libva-utils-2.22.0-4.fc42.x86_64
Module libigdgmm.so.12 from rpm intel-gmmlib-22.7.2-1.fc42.x86_64
Module iHD_drv_video.so from rpm intel-media-driver-free-25.2.6-1.fc42.x86_64
Module libXau.so.6 from rpm libXau-1.0.12-2.fc42.x86_64
Module libffi.so.8 from rpm libffi-3.4.6-5.fc42.x86_64
Module libxcb-dri3.so.0 from rpm libxcb-1.17.0-5.fc42.x86_64
Module libX11-xcb.so.1 from rpm libX11-1.8.12-1.fc42.x86_64
Module libXfixes.so.3 from rpm libXfixes-6.0.1-5.fc42.x86_64
Module libXext.so.6 from rpm libXext-1.3.6-3.fc42.x86_64
Module libxcb.so.1 from rpm libxcb-1.17.0-5.fc42.x86_64
Module libwayland-client.so.0 from rpm wayland-1.24.0-1.fc42.x86_64
Module libdrm.so.2 from rpm libdrm-2.4.125-1.fc42.x86_64
Module libX11.so.6 from rpm libX11-1.8.12-1.fc42.x86_64
Stack trace of thread 32831:
#0 0x00007f808bdda020 __memset_avx2_unaligned_erms (libc.so.6 + 0x146020)
#1 0x00007f808b74638c _Z29Mhw_StateHeapInterface_CreatePP25_MHW_STATE_HEAP_INTERFACE23MHW_STATE_HEAP_SETTINGS (iHD_drv_video.so + 0x74638c)
#2 0x00007f808b6c4bde _ZN3mhw6render4ImplINS0_12xe2_hpg_next3CmdEE13AllocateHeapsE23MHW_STATE_HEAP_SETTINGS (iHD_drv_video.so + 0x6c4bde)
#3 0x00007f808b6652de _ZN34XRenderHal_Platform_Interface_Next13AllocateHeapsEP20_RENDERHAL_INTERFACE23MHW_STATE_HEAP_SETTINGS (iHD_drv_video.so + 0x6652de)
#4 0x00007f808b663507 _Z28RenderHal_AllocateStateHeapsP20_RENDERHAL_INTERFACEP30_RENDERHAL_STATE_HEAP_SETTINGS (iHD_drv_video.so + 0x663507)
#5 0x00007f808b659775 _Z20RenderHal_InitializeP20_RENDERHAL_INTERFACEP19_RENDERHAL_SETTINGS (iHD_drv_video.so + 0x659775)
#6 0x00007f808b64bc56 _ZN19RenderCopyStateNext10InitializeEv (iHD_drv_video.so + 0x64bc56)
#7 0x00007f808b6fd5ca _ZN16McpyDeviceNext_TI17MhwInterfacesNext26MediaCopyStateXe2_Hpm_BaseE10InitializeEP14_MOS_INTERFACE (iHD_drv_video.so + 0x6fd5ca)
#8 0x00007f808b6722fb _ZN14McpyDeviceNext13CreateFactoryEPv (iHD_drv_video.so + 0x6722fb)
#9 0x00007f808b085a89 _ZN21OsContextSpecificNext4InitEPv (iHD_drv_video.so + 0x85a89)
#10 0x00007f808b22561c _Z25DdiMedia_InitMediaContextP15VADriverContextiPiS1_Rb.constprop.0 (iHD_drv_video.so + 0x22561c)
#11 0x00007f808b231b0a __vaDriverInit_1_22 (iHD_drv_video.so + 0x231b0a)
#12 0x00007f808c0054af va_openDriver (libva.so.2 + 0x14af)
#13 0x000055fcd6258d01 main (/usr/bin/vainfo + 0xd01)
#14 0x00007f808bc97575 __libc_start_call_main (libc.so.6 + 0x3575)
#15 0x00007f808bc97628 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x3628)
#16 0x000055fcd6259255 _start (/usr/bin/vainfo + 0x1255)
ELF object binary architecture: AMD x86-64
nrrv
sudo dmesg | grep -E "(firmware|GuC|HuC|DMC)" | grep -E "(xe|i915|0b:00)"
[ 7.104754] xe 0000:0b:00.0: [drm] Using GuC firmware from xe/bmg_guc_70.bin version 70.45.2
[ 7.126396] xe 0000:0b:00.0: [drm] Using GuC firmware from xe/bmg_guc_70.bin version 70.45.2
[ 7.136865] xe 0000:0b:00.0: [drm] Using HuC firmware from xe/bmg_huc.bin version 8.2.10
[ 7.243827] xe 0000:0b:00.0: [drm] Finished loading DMC firmware i915/bmg_dmc.bin (v2.6)
[ 7.791679] xe 0000:0b:00.0: [drm] Failed to read power limits, check card firmware !
So firmware?
nrrv
sudo dmesg | grep "xe 0000:0b:00.0"
[ 7.093573] xe 0000:0b:00.0: vgaarb: deactivate vga console
[ 7.093848] xe 0000:0b:00.0: [drm] Found battlemage (device ID e20b) discrete display version 14.01 stepping B0
[ 7.147714] xe 0000:0b:00.0: [drm] Attempting to resize bar from 256MiB -> 16384MiB
[ 7.147718] xe 0000:0b:00.0: [drm] Can't resize VRAM BAR - platform support is missing. Consider enabling 'Resizable BAR' support in your BIOS
[ 7.147729] xe 0000:0b:00.0: [drm] VISIBLE VRAM: 0x00000000d0000000, 0x0000000010000000
[ 7.147754] xe 0000:0b:00.0: [drm] Small BAR device
[ 7.147756] xe 0000:0b:00.0: [drm] VRAM[0, 0]: Actual physical size 0x0000000300000000, usable size exclude stolen 0x00000002fb800000, CPU accessible size 0x0000000010000000
[ 7.147759] xe 0000:0b:00.0: [drm] VRAM[0, 0]: DPA range: [0x0000000000000000-300000000], io range: [0x00000000d0000000-e0000000]
[ 7.147762] xe 0000:0b:00.0: [drm] VRAM: 0x0000000300000000 is larger than resource 0x0000000010000000
[ 7.147764] xe 0000:0b:00.0: [drm] Total VRAM: 0x00000000d0000000, 0x0000000300000000
[ 7.147766] xe 0000:0b:00.0: [drm] Available VRAM: 0x00000000d0000000, 0x00000002fb800000
[ 7.232389] xe 0000:0b:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 7.542139] xe 0000:0b:00.0: [drm] ccs2 fused off
[ 7.542143] xe 0000:0b:00.0: [drm] ccs3 fused off
[ 7.562837] xe 0000:0b:00.0: [drm] vcs1 fused off
[ 7.562841] xe 0000:0b:00.0: [drm] vcs3 fused off
[ 7.562844] xe 0000:0b:00.0: [drm] vcs4 fused off
[ 7.562846] xe 0000:0b:00.0: [drm] vcs5 fused off
[ 7.562848] xe 0000:0b:00.0: [drm] vcs6 fused off
[ 7.562850] xe 0000:0b:00.0: [drm] vcs7 fused off
[ 7.562852] xe 0000:0b:00.0: [drm] vecs2 fused off
[ 7.562854] xe 0000:0b:00.0: [drm] vecs3 fused off
[ 7.782123] xe 0000:0b:00.0: [drm] fb0: xedrmfb frame buffer device
[ 7.791642] xe 0000:0b:00.0: [drm] *ERROR* PCODE Mailbox failed: 1 Illegal Command
[ 7.791677] xe 0000:0b:00.0: [drm] *ERROR* PCODE Mailbox failed: 1 Illegal Command
[ 7.791860] xe 0000:0b:00.0: [drm] *ERROR* PCODE Mailbox failed: 1 Illegal Command
[ 7.791977] xe 0000:0b:00.0: [drm] *ERROR* PCODE Mailbox failed: 1 Illegal Command
[ 7.792192] xe 0000:0b:00.0: [drm] *ERROR* PCODE Mailbox failed: 1 Illegal Command
[ 7.792227] xe 0000:0b:00.0: [drm] *ERROR* PCODE Mailbox failed: 1 Illegal Command
nrrv
gdb --batch --ex run --ex bt --ex quit --args vainfo
This GDB supports auto-downloading debuginfo from the following URLs:
<https://debuginfod.fedoraproject.org/>
Enable debuginfod for this session? (y or [n]) [answered N; input not from terminal]
Debuginfod has been disabled.
To make this setting permanent, add 'set debuginfod enabled off' to .gdbinit.
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
libva info: Open new log file /tmp/libva.log.195814.thd-0x0000e579 for the thread 0x0000e579
libva info: LIBVA_TRACE is on, save log into /tmp/libva.log.195814.thd-0x0000e579
libva info: Trying to open /usr/local/lib64/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_23
Program received signal SIGBUS, Bus error.
0x00007ffff7d39020 in __memset_avx2_unaligned_erms () from /lib64/libc.so.6
#0 0x00007ffff7d39020 in __memset_avx2_unaligned_erms () from /lib64/libc.so.6
#1 0x00007ffff5cd6419 in XMHW_STATE_HEAP_INTERFACE::InitializeInterface (this=0x5555555f8fa0, StateHeapSettings=...) at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/hw/mhw_state_heap.cpp:1083
#2 0x00007ffff5cd6843 in Mhw_StateHeapInterface_Create (ppStateHeapInterface=<optimized out>, StateHeapSettings=...) at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/hw/mhw_state_heap.cpp:680
#3 0x00007ffff5c15a3d in mhw::render::Impl<mhw::render::xe2_hpg_next::Cmd>::AllocateHeaps (this=<optimized out>, stateHeapSettings=...) at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/hw/mhw_render_impl.h:167
#4 0x00007ffff5bc7bab in XRenderHal_Platform_Interface_Next::AllocateHeaps (this=<optimized out>, pRenderHal=<optimized out>, MhwStateHeapSettings=...) at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/renderhal/renderhal_platform_interface_next.cpp:807
#5 0x00007ffff5bc427e in RenderHal_AllocateStateHeaps (pRenderHal=0x5555555f64f0, pSettings=0x5555555f6598) at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/renderhal/renderhal.cpp:1502
#6 0x00007ffff5bc295c in RenderHal_Initialize (pRenderHal=0x5555555f64f0, pSettings=<optimized out>) at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/renderhal/renderhal.cpp:5380
#7 0x00007ffff5bb0026 in RenderCopyStateNext::Initialize (this=0x5555555f5f90) at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/shared/mediacopy/media_render_copy_next.cpp:121
#8 0x00007ffff5c8a13d in McpyDeviceNext_T<MhwInterfacesNext, MediaCopyStateXe2_Hpm_Base>::Initialize (this=0x5555555eea80, osInterface=<optimized out>) at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/media_interfaces/media_interfaces_mcpy_next.h:127
#9 0x00007ffff5bd326b in McpyDeviceNext::CreateFactory (osDriverContext=osDriverContext@entry=0x7fffffff63c0) at /home/nrv/build/intel-media/media-driver/media_softlet/linux/common/media_interfaces/media_interfaces_next.cpp:414
#10 0x00007ffff5290370 in MosMediaCopyBase::MosMediaCopyBase (this=0x5555555ece80, mosCtx=0x7fffffff63c0) at /home/nrv/build/intel-media/media-driver/media_softlet/linux/common/os/mos_mediacopy_base.cpp:34
#11 MosMediaCopyBase::MosMediaCopyBase (this=this@entry=0x5555555ece80, mosCtx=mosCtx@entry=0x7fffffff63c0) at /home/nrv/build/intel-media/media-driver/media_softlet/linux/common/os/mos_mediacopy_base.cpp:31
#12 0x00007ffff5251c22 in MosMediaCopy::MosMediaCopy (this=this@entry=0x5555555ece80, mosCtx=mosCtx@entry=0x7fffffff63c0) at /home/nrv/build/intel-media/media-driver/media_driver/linux/common/os/mos_mediacopy.cpp:32
#13 0x00007ffff5289215 in MosUtilities::MosNewUtil<MosMediaCopy, _MOS_OS_CONTEXT*&> () at /home/nrv/build/intel-media/media-driver/media_softlet/agnostic/common/os/mos_utilities.h:2998
#14 OsContextSpecificNext::Init (this=0x5555555ad9d0, ddiDriverContext=<optimized out>) at /home/nrv/build/intel-media/media-driver/media_softlet/linux/common/os/mos_context_specific_next.cpp:329
#15 0x00007ffff5468b61 in DdiMedia_InitMediaContext (ctx=ctx@entry=0x555555561f50, devicefd=4, major_version=major_version@entry=0x0, minor_version=minor_version@entry=0x0, apoDdiEnabled=@0x7fffffffd2ef: false) at /home/nrv/build/intel-media/media-driver/media_driver/linux/common/ddi/media_libva.cpp:1786
#16 0x00007ffff5469986 in DdiMedia__Initialize (ctx=0x555555561f50, major_version=0x0, minor_version=0x0) at /home/nrv/build/intel-media/media-driver/media_driver/linux/common/ddi/media_libva.cpp:1691
#17 __vaDriverInit (ctx=0x555555561f50) at /home/nrv/build/intel-media/media-driver/media_driver/linux/common/ddi/media_libva.cpp:7503
#18 __vaDriverInit_1_23 (ctx=0x555555561f50) at /home/nrv/build/intel-media/media-driver/media_driver/linux/common/ddi/media_libva.cpp:7529
#19 0x00007ffff7f874af in va_openDriver (dpy=0x555555561710, driver_name=<optimized out>) at va.c:478
#20 va_new_opendriver (dpy=0x555555561710) at va.c:714
#21 vaInitialize (dpy=0x555555561710, major_version=0x7fffffffd644, minor_version=0x7fffffffd640) at va.c:743
#22 0x0000555555554d01 in main ()
A debugging session is active.
Inferior 1 [process 58745] will be killed.
Quit anyway? (y or n) [answered Y; input not from terminal]
nrrv
The crash happens during a memory mapping operation:
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, 4, 0x1682b1000) = 0x7fa10749a000
--- SIGBUS {si_signo=SIGBUS, si_code=BUS_ADRERR, si_addr=0x7fa10749a000} ---
The driver is trying to map GPU memory at address 0x7fa10749a000 but gets a BUS_ADRERR
nrrv
