23854 Discussions
Inter HD Graphics Control Panel Forgetting Monitor Settings
GRoe2
I am using the Intel Graphics Control Panel that comes with 10.18.14.4222. I have an HD4600 on my Laptop running Win 8.1 64 bit. I have an external monitor connect via HDMI and use that as my ONLY monitor.
I usually put my laptop to sleep, rather and shutting it down, by closing the screen. When I wake it up by opening the screen. it will change my single monitor setting to extended monitor at least 50% of the time and I have open the control panel to set it back.
I cannot not seem to get profiles to work correctly. If I apply all my settings including the single monitor and save it to a profile a profile is created. When I have the issue, the settings will always say Current Settings. How do I get it to always use the profile that I created? Also, if I wake of the laptop and have the issue and attempt to choose the profile that I saved, the screen will go so dark that I cannot see much of anything.
Why does my settings change to extended monitor at wake up?
Why doesn't my profile seem to work?
Separate question: will there be a new drive and control panel with win 10?
Allan_J_Intel1
I am currently researching on this issue. As soon as I can, I will send you a message with my findings. Thank you for your patience and understanding.
Allan.
