23810 Discussions
Iris Pro 6200 refresh rate problem
AOles
Hello! I`m using i5 5675 with Iris Pro 6200, and I`ve got a problem in full screen mod on every game which using DirectX 10 or 11. So, when i switching any dx10/11 game at 1920x1080 / 60Hz in full screen i`m getting blinking image (it looks like an interlaced scan, but display works at progressive 60p!). There is no problem when game runs in dx9! My config is Windows 10 1709 x64 and last 15.40 iGPU driver. Display Dell 1080p 60hz. Can anyone suppose how to fix the problem?
Thank you very much for contacting the Intel Communities Team, anthytony.
In order for me to assist you better, please provide me with the .txt file that the http://https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- System Support Utility will generate. I would like to have as well a video or a screenshot of the error.To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box. Furthermore, which is the cable you are using to connect your system to the display? Which is the model of the monitor? And, in which games this error is shown?
Finally, have you tested your system with another monitor or cable?
Antony S.
AOles
Thanks for the response. I decided to try older beta driver (there was description with such problem) and it works normaly.
