23769 Discussions
Iris Xe Multiple Monitor Question
JohnEnglish
I have a HP Elitebook x360 1030 G8 with a 1185G7 CPU. I would like to connect it to 3 Dell P2425DE monitors. They're USB-C hub monitors with 2560x1440 resolution so they can be daisy chained together.
Looking at the Iris Xe specs, it seems like this would work but I would like to confirm before I purchase the monitors.
StanleyB_Intel
Hello JohnEnglish,
Thank you for contacting the Intel Community Forum.
Based on my analysis of the Dell P2425DE specifications, the display supports a maximum signal bandwidth of 11.06 Gbps (distributed as 3.69 Gbps per channel). This bandwidth requirement is well within the capabilities of your Integrated Intel® Iris® Xe Graphics, which provides a maximum signal bandwidth of 59.72 Gbps (19.91 Gbps per channel), ensuring full compatibility between the devices.
Should you have additional technical inquiries, please feel free to ask.
Stanley B.
MUC
Honored Contributor I
Yes, that should work. Please also note these instructions from the monitor's user manual:
* 2560 x 1440 @ 60 Hz
StanleyB_Intel
Hello JohnEnglish,
I hope you had the chance to look over the posted information. When you have a moment, please feel free to get in touch if you require any additional assistance or have questions.
Stanley B.
StanleyB_Intel
Hello JohnEnglish,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Stanley B.
