22862 Discussions
Irritating graphics problem that I can't figure out how to fix - Intel HD Graphics 2000 (Virtual chocolate-chip cookies for whoever helps me with this!) ;-)
DBari1
I'm getting pretty frustrated with my wonky display, so if anyone has a suggestion to help me, you'll have my undying gratitude and virtual chocolate-chip cookies in thanks! 🙂 And if that's not enough for you there's always my firstborn child.
So, the Problem:
My display has bright, horizontal magenta lines across the top of the screen. The longer my computer is on, the more the problem grows; more lines appear, they get thicker, and brighter, and they go further down the screen until the top third of the screen is barely visible through the distortion.
By then, there are also vertical lines along the right-hand (my right, the monitor's left) side of the screen - though that appears more as a smear of colour, which extends further at the bottom of the screen than it does at the top. If the computer is left on too long, the entire screen is distorted, and the only way to fix it is to shut down the computer and let it rest for a bit before turning it back on.
My (rather slipshod) Temporary Solution:
Adjusting the display settings (colour, saturation, brightness, hue, etc.) minimized the problem, but the adjustments took a lot of colour and brightness out of the display; it's very muted and dull now, and it's harder to see things on the screen. Not to mention, the distortion is still there; it's just minimal (relegated to the very top of the screen and only extending about a half an inch down), and not very bright or visible anymore - rather than bright, magenta lines, it just looks like simple distortion.
Is there any way to fix this? I'll post the graphics card info below. While I recently upgraded to Windows 10, this problem was occurring for a few months before that.
_____________________________________________________________________________________
System Information:
Processor Graphics Information:
Intel(R) HD Graphics 2000 | Video BIOS: 2111.0 | Current Graphics Mode: 1680 by 1050
Intel(R) HD Graphics 2000:
Driver Version: 9.17.10.4229 | Operating System: Microsoft Windows 10 Home Version (10.0.10586) | DirectX* Version: 11.0 |Physical Memory: 6087 MB | Processor: Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz | Processor Speed: 3293 MHz | Vendor ID: 8086 | Device ID: 0102 | Device Revision: 09
If you need more information on the graphics card, I'll look for it and post it ASAP.
While I'm 99% certain it's the graphics card and not the monitor, the monitor info is below, just in case.
Monitor Acer X223W | Generic PnP Monitor Information:
General Info:
Display Type: Analog | Serial Number: ACR0050 | DDC2 Protocol: Supported | Gamma: 2.2 | Connector Type: VGA | Device Type: CRT
<p style="text-align: justify; color: # 3d3d3d; font-family: intel-clear, arial, helvetica, 'helvetica neue', verdana, sans-serif; font-size: 13px; backg...
JSkau
New Contributor II
Does your computer have DVI(-D) output? Or if HDMI, you could try a HDMI to DVI adapter/cable. Or - try adjusting the refresh rating - some LCDs don't take too kindly on being addressed analog as a CRT monitor.
Allan_J_Intel1
Please bear in mind the Intel® HD Graphics 2000 does not have Windows® 10 graphics driver support.
Allan.
