23807 Discussions
Is Intel(R) HD Graphics 530 HDCP compliant
JIppo
AlHill
"Does the HDMI interface support HDCP?
HDCP is supported by the HDMI interface in all Intel® Core™ Processors with Intel® Iris® and Intel® HD Graphics. It is also supported for all Intel® Pentium® Processors and Celeron® Processors with Intel® HD Graphics."
https://www.intel.com/content/www/us/en/support/articles/000005485/graphics-drivers.html
Doc
JIppo
Thanks for the info. The reason I ask is because;
I am connecting an external Blu ray player to my desk top (inspiron 3250), via USB connection;
Monitor has; VGA, DVI-D, and DP connections. PC has , VGA, HDMI, only.
I have have tried to use a HDMI (pc) to DP (monitor) cable; however the monitor does not recognise the DP connect. Is this a cable connect issue or something else?
Now I'm sure if the Intel HD 530 graphics is HDCP compliant, thanks to your info.
I believe the monitor P2014H is also HDCP compliant.
My media player will start to play the BR, and then I get the HDCP warning. It think it can only be coming through the VGA, (when it is disconnected Monitor display disappears).
Any Ideas?
AlHill
Try a better quality cable?
Doc
