22919 Discussions
Is there a global setting to turn off AA in the IntelHD 3000 control panel?
Good day! I was wondering how I could go about turning off AA for all applications by default. Since Intel's control panel only gives me the option to let the application decide in that regard.
I looked it up online, but my control panel doesn't look like others I've seen, and my only guess is that they're using newer versions of Intel's graphic chips.
Hello Tairetsu,
Unfortunately, that option is not available on this graphic version, this option is available on later versions.
At this point, if you are using some application that require this to be off, you may need to try and disable AA from the application you are using, if it is available.
Ivan
