23537 Discussions
Is worthy changing DVMT pre-allocated?
HViei1
I know that DVMT are a feature in Intel chipsets that allocated vram when it's necessary, but in bios says that I can change the DVMT pre-allocated up to 1024MB (by deafault it was 64MB). Ok, I changed just for testing, the dedicated vram in properties showed 1024MB, and the games performance got worst! I changed to default and got better. The question is: I can pre-allocated down to 32MB, if I do so, will my graphic performance get better than is in 64MB?
When I buyed my PC, the site said that vram was up to 1GB, but when I checked my pc said that has 32MB of dedicated video, then I searched about DVTM and learned about it. I want to change mainly because the games that tecnically my pc can run easily (lower than 1GB of vram), poorly runs if I don't put the graphics and resolution in low.
Hello henriquevpp,
Thank you for contact the Intel Technical Support.
In regards to your question about the DVTM, you can change the setting in BIOS or in the Operating System.
I will like to know more information about your PC.
Could you run the Intel® System Support Utility for Windows and share the results (attach the logs).
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
HViei1
Thanks! Ok, I'll paste the log in the post. And I know that I can change in BIOS. When I put the pre-allocated in low a set of memory (by default 64MB), my performance it's better than when I put in a higher set of memory (like 1024MB), I want to know if I put the set of memory in 32MB (lower than 64), my performance will get better.
LOG:
# SSU Scan Information
Scan Info:
Version:"2.5.0.12"
Date:"01/29/2018"
Time:"00:00:26.4642507"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"INTEL Corporation"
BIOS Mode:"Legacy"
BIOS Version/Date:"American Megatrends Inc. 4.6.5 , 07/19/2017"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz , GenuineIntel"
Secure Boot State:"Not Available"
SMBIOS Version:"2.7"
Sound Card:"Realtek High Definition Audio"
Sound Card:"Áudio Intel(R) para telas"
System Manufacturer:"To be filled by O.E.M."
System Model:"To be filled by O.E.M."
System SKU:"To be filled by O.E.M."
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"10.18.10.4653"
- "Intel(R) HD Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"2,06 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) HD Graphics"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics"
CoInstallers:"igfxCoIn_v4653.dll, CoDeviceInstall"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"04/06/2017 09:00"
Driver Path:"C:\Windows\system32\DRIVERS\igdkmd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem9.inf"
INF Section:"iIVBD_w10"
Install Date:"Not Available"
Installed Drivers:"igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"11.2"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_0152&SUBSYS_21118086&REV_09\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"75 Hz"
Refresh Rate - Minimum:"59 Hz"
Resolution:"1366 X 768"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) HD Graphics Family"
- "Memory"
Physical Memory (Available):"5,13 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"7,90 GB"
- "BANK 0"
Capacity:"4 GB"
Channel:"ChannelA-DIMM0"
Configured Clock Speed:"1600 MHz"
Configured Voltage:"Not Available"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"Not Available"
Manufacturer:"08B6"
Maximum Voltage:"Not Available"
Memory Type:"DDR3"
Minimum Voltage:"Not Available"
Part Number:"MD3512NSA-CA3G1"
Serial Number:"51380001"
Status:"Not Available"
Type:"Synchronous"
- "BANK 2"
Capacity:"4 GB"
Channel:"ChannelB-DIMM0"
Form Factor:"DIMM"
Manufacturer:"08B6"
Memory Type:"DDR3"
Serial Number:"43380001"
Type:"Synchronous"
- "Motherboard"
BIOS:"BIOS Date: 07/19/17 16:45:53 Ver: 04.06.05, BIOS Date: 07/19/17 16:45:53 Ver: 04.06.05"
Caption:"Placa-mãe"
- "Chipset":"Intel(R) 6 Series/C200 Series"
Link:"<a class="jive-link-exter...
Hello henriquevvp,
Thanks for your reply.
About Dynamic video memory technology (DVMT):
  • The system manufacturer sets amount of pre-allocated memory via the system BIOS. Depending on the system BIOS implementation, the amount may or may not be configurable.
  • Dynamically allocates and de-allocates the optimum amount of memory for balanced 2D, 3D graphics, and system performance.
  • Returns the memory to the operating system when no longer required. For example, the OS views the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver) as an application.
  • DVMT aligns with the design guidelines for Microsoft drivers. It dynamically uses only the system memory needed and returns these resources to the operating system when finished. Some integrated graphics solutions permanently dedicate large amounts of memory. Dedicated memory ends up wasted.
For more information about DVMT, please check the following links (Frequently Asked Questions):
https://www.intel.com/content/www/us/en/support/articles/000006532/graphics-drivers/legacy-graphics.html https://www.intel.com/content/www/us/en/support/articles/000006532/graphics-drivers/legacy-graphics.html
https://www.intel.com/content/www/us/en/support/articles/000020962/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000020962/graphics-drivers.html
Ricardo
Hello henriquevpp,
Is there any other question I can assist you with? If you require any further information, let us know.
Ricardo.
