23851 Discussions
Issue on 'mouse pointer change' event
I'm experiencing unwanted behavior when the mouse pointer is changing.
Technically the problem is(as far as I can tell) that the driver is designed so it first change the mouse pointer, and at the next frame it updated its offset.
The best way to reproduce it is to run winamp and slowly to move mouse over and out winamp window.
The behavior is on Intel 965(Driver: 13.01.2010, 6.14.10.5218 and older).
Does anyone has the same issue, know how to fix it possibly? Or maybe intel programmers can take a look into it.
Regards.
I have the same issue...
