23692 Discussions
Issue with OpenGL code on Intel HD 4000 card (Windows 8)
ATayl6
I have some OpenGL code that seems to work fine on every setup bar Intel HD 4000 on Windows 8.
I have reproduced an example showing the problem (can be compiled using Visual C++)
On a working system it looks like
http://i39.tinypic.com/118zhvn.png[/IMG] http://i39.tinypic.com/118zhvn.png
On Intel HD 4000 on Windows 8
http://i42.tinypic.com/2ez1qh3.png[/IMG] http://i42.tinypic.com/2ez1qh3.png
I am assuming this is a driver issue (have tried the latest drivers but no joy) although can't rule out an issue with the code.
Can anyone help?
# include
# include
# include
// Function Declarations
LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam);
void EnableOpenGL(HWND hWnd, HDC * hDC, HGLRC * hRC);
void DisableOpenGL(HWND hWnd, HDC hDC, HGLRC hRC);
// WinMain
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPSTR lpCmdLine, int iCmdShow)
WNDCLASS wc;
HWND hWnd;
HDC hDC;
HGLRC hRC;
MSG msg;
BOOL quit = FALSE;
float theta = 0.0f;
// register window class
wc.style = CS_OWNDC;
wc.lpfnWndProc = WndProc;
wc.cbClsExtra = 0;
wc.cbWndExtra = 0;
wc.hInstance = hInstance;
wc.hIcon = LoadIcon(NULL, IDI_APPLICATION);
wc.hCursor = LoadCursor(NULL, IDC_ARROW);
wc.hbrBackground = (HBRUSH) GetStockObject(BLACK_BRUSH);
wc.lpszMenuName = NULL;
wc.lpszClassName = "GLSample";
RegisterClass(&wc);
// create main window
hWnd = CreateWindow(
"GLSample", "OpenGL Sample",
WS_CAPTION | WS_POPUPWINDOW | WS_VISIBLE,
0, 0, 512, 512,
NULL, NULL, hInstance, NULL);
// enable OpenGL for the window
EnableOpenGL(hWnd, &hDC, &hRC);
// program main loop
while (!quit)
// check for messages
if (PeekMessage(&msg, NULL, 0, 0, PM_REMOVE))
// handle or dispatch messages
if (msg.message == WM_QUIT)
quit = TRUE;
else
TranslateMessage(&msg);
DispatchMessage(&msg);
else
glLoadIdentity();
gluOrtho2D(-1.5938962727771744, 1.5938962727771744, -1.5707963267948966, 1.5707963267948966);
glBegin(GL_LINE_LOOP);
glVertex2d(-1.093332, -0.388151);
glVertex2d(-1.092969, -0.388418);
glVertex2d(-1.093067, -0.389266);
glVertex2d(-1.092257, -0.389503);
glVertex2d(-1.091499, -0.389893);
glVertex2d(-1.090951, -0.390575);
glVertex2d(-1.090157, -0.390978);
glVertex2d(-1.089468, -0.391521);
glVertex2d(-1.088742, -0.392055);
glVertex2d(-1.087883, -0.392249);
glVertex2d(-1.087084, -0.392626);
glVertex2d(-1.086413, -0.393203);
glVertex2d(-1.086254, -0.393989);
glVertex2d(-1.086176, -0.394827);
glVertex2d(-1.085459, -0.395254);
glVertex2d(-1.085169, -0.395996);
glVertex2d(-1.084897, -0.396781);
glVertex2d(-1.084354, -0.397474);
glVertex2d(-1.083956, -0.398172);
glVertex2d(-1.083321, -0.398783);
glVertex2d(-1.082729, -0.399405);
glVertex2d(-1.082467, -0.400180);
glVertex2d(-1.082225, -0.400995);
glVertex2d(-1.081717, -0.401707);
glVertex2d(-1.081027, -0.402269);
glVertex2d(-1.080291, -0.402681);
glVertex2d(-1.079516, -0.403059);
glVertex2d(-1.078943, -0.403656);
glVertex2d(-1.078322, -0.404300);
glVertex2d(-1.077667, -0.404873);
glVertex2d(-1.077484, -0.405731);
glVertex2d(-1.076762, -0.406152);
glVertex2d(-1.075884, -0.406375);
glVertex2d(-1.075022, -0.406608);
glVertex2d(-1.074493, -0.407311);
glVertex2d(-1.073843, -0.407932);
glVertex2d(-1.073323, -0.408644);
glVertex2d(-1.072456, -0.408786);
glVertex2d(-1.071758, -0.409285);
glVertex2d(-1.070857, -0.409484);
glVertex2d(-1.070075, -0.409861);
glVertex2d(-1.069489, -0.410512);
glVertex2d(-1.068698, -0.410995);
glVertex2d(-1.067836, -0.411107);
glVertex2d(-1.067201, -0.411728);
glVertex2d(-1.066532, -0.412285);
glVertex2d(-1.066634, -0.413133);
glVertex2d(-1.066101, -0.413807);
glVertex2d(-1.065469, -0.414428);
glVertex2d(-1.065068, -0.415170);
glVertex2d(-1.064413, -0.415767);
glVertex2d(-1.063483, -0.415732);
glVertex2d(-1.062698, -0.416106);
glVertex2d(-1.062019, -0.416678);
glVertex2d(-1.061062, -0.416697);
glVertex2d(-1.060094, -0.416654);
glVertex2d(-1.059338, -0.417027);
glVertex2d(-1.058474, -0.417017);
glVertex2d(-1.057568, -0.417294);
glVertex2d(-1.057204, -0.418026);
glVertex2d(-1.056303, -0.418113);
glVertex2d(-1.055507, -0.418516);
glVertex2d(-1.054678, -0.418734);
glVertex2d(-1.053737, -0.418715);
glVertex2d(-1.052943, -0.419190);
glVertex2d(-1.052074, -0.419547);
glVertex2d(-1.051119, -0.419520);
glVertex2d(-1.050170, -0.419607);
glVertex2d(-1.049325, -0.419460);
glVertex2d(-1.048452, -0.419198);
glVertex2d(-1.047541, -0.419239);
glVertex2d(-1.046582, -0.419825);
glVertex2d(-1.045594, -0.420411);
glVertex2d(-1.044648, -0.420998);
glVertex2d(-1.043674, -0.421584);
glVertex2d(-1.042728, -0.422171);
glVertex2d(-1.041757, -0.422757);
glVertex2d(-1.040797, -0.423344);
glVertex2d(-1.039834, -0.423930);
glVertex2d(-1.038864, -0.424513);
glVertex2d(-1.037980, -0.425037);
glVertex2d(-1.037424, -0.425686);
glVertex2d(-1.036745, -0.426171);
glVertex2d(-1.036153, -0.426806);
glVertex2d(-1.035561, -0.427445);
glVertex2d(-1.034792, -0.427867);
glVertex2d(-1.033982, -0.428285);
<p...
DArce
Valued Contributor III
Let me check what would be the appropriate channel of support for this.
While I do so, could you please indicate what is the driver versions you have tested with?
ATayl6
Thanks for your offer of help
We have tested with a variety of drivers including the latest as downloaded from
http://www.intel.com/p/en_US/support/detect http://www.intel.com/p/en_US/support/detect
This issue is being reported by a number of our customers. The only common factor is Windows 8 and that graphics card.
Note it isn't a Windows 8 issue in general as all works fine on other PCs with different graphics cards.
ATayl6
@Diego_Intel Any update on this? We are keen to find a solution to this issue.
Regards.
Alastair
DArce
Hello Alastair, we are still waiting for a response on this, you may alternatively check through http://software.intel.com/en-us/forum Forums | Intel® Developer Zone which is the actual channel of support for these concerns
ATayl6
We have just had a report of the same drawing issues with a PC with a Intel HD 4000 card but running Windows 7.
Any help on this matter would be much appreciated as it's now a number of clients experiencing this problem.
DArce
We have been able to replicate the issue and now we are working on implementing this fix on a future driver release.
As you may know, we may not provide an estimated time for this to happen.
ATayl6
@ Diego_Intel Thank you for the update. Will I be notified when the fix is available?
DArce
Yes, we will let you know when the fix is available in our web site.
SDunl
hello,
I also have an issue with my Surface Pro and a program called Sketchup Make. If I role back my drivers it work but when windows updates my drivers again the program breaks.
DArce
SDunlop, a fix for the issue being discussed here is to be available in a future driver release. If your issue is related to this same topic, then please wait for this fix to be available. If your concern is related to a different software/problem, then please create a separate thread and provide full system configuration (device models, driver/application versions and steps to reproduce the issue)
SDunl
Hello Diego,
I believe this is the same issue and I just wanted to provide some additional information and resource related information so that the engineering/development team have enough information to properly test the new drivers before releasing them. Obviously I would much rather see a driver release that fixes all OpenGL related issues in one driver rather than having to continuously update.
DArce
Alright. Thank you for your feedback, you may test this when the new driver is released. As a side note, I would like to let you know that I played a little bit with Sketchup Make using Microsoft* Windows* 8, with drivers version
9.18.10.3165 with Intel® HD Graphics 4000 and it worked fine.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=3165 9.18.10.3165 Download Center
if your issue still persists, then please open a new thread with your full information on your system configuration, dxdiag report and steps and/or a file to reproduce your issue.
DArce
I would like to let you know that the issue has been investigated and replicated, and a fix will be available in a future driver release. However there is no estimated date for this to be released at this moment.
ATayl6
Is there any update available yet as it's been 4 months since I raised this issue and we are keen to pass on a solution to our customers.
Regards.
DArce
We were notified that the fix would be available on a future driver release however no ETA is available for this.
