22891 Discussions
Issues opening "Advanced Mode" in Intel Graphics and Media Control Panel
I'm trying to access the "Advanced Mode" in the Intel Graphics and Media Control Panel but I am getting an error:
"GfxUI has stopped working"
I can get into Basic and Wizard modes just fine.
I am using Windows 8 Pro 64-bit (full RTM) with a 1st gen Core i3 with Intel HD Graphics. I have the latest driver installed from Windows Update. Any advice on this issue would be greatly appreciated.
Here is a dump from the control panel's system information tab:
Intel® HD Graphics (Core i3)
Report Date: 11/30/2012
Report Time[hr:mm:ss]: 18:21:23
Driver Version: 8.15.10.2858
Operating System: (6.2.9200)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 5940 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 90 MB
Processor: Intel64 Family 6 Model 37 Stepping 5
Processor Speed: 2527 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 18
* Accelerator Information *
Accelerator in Use: Intel(R) HD Graphics
Video BIOS: 2026.1
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
Active Notebook Displays: 1
* Digital Television *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
720 by 480 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 19 C9 00 00 00 00 00 00
00 15 01 03 80 00 00 78 0A 2F CD A3 54 45 97 24
11 46 47 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 10 09 00 00 00 1E 8C 0A D0 8A 20 E0 2D 10
10 3E 96 00 10 09 00 00 00 18 00 00 00 FC 00 4C
43 44 20 54 56 0A 20 20 20 20 20 20 00 00 00 FD
00 17 3F 0F 45 0F 00 0A 20 20 20 20 20 20 01 58
02 03 20 70 4A 10 03 20 22 04 02 05 06 07 01 26
09 07 07 15 07 50 83 01 00 00 65 03 0C 00 10 00
01 1D 80 3E 73 38 2D 40 7E 2C 45 80 10 09 00 00
00 1E 01 1D 80 18 71 38 2D 40 58 2C 45 00 10 09
00 00 00 1E 01 1D 00 72 51 D0 1E 20 6E 28 55 00
10 09 00 00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E
96 00 04 03 00 00 00 18 01 1D 80 18 71 1C 16 20
58 2C 25 00 10 09 00 00 00 9E 00 00 00 00 00 82
* Built-in Display *
Gamma Value: 2.2
Maximum Image Size:
Horizontal: 12.20 inches
Vertical: 07.09 inches
1366 by 768 (60 Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 25 CC 14 00 00 00 00 00
00 14 01 03 80 1F 12 78 0A 87 F5 94 57 4F 8C 27
27 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 BC 1B 56 84 50 00 16 30 30 20
14 00 35 AE 10 00 00 18 BC 1B 56 84 50 00 16 30
30 20 14 00 35 AE 10 00 00 00 00 00 00 FE 00 48
52 31 56 54 80 31 34 30 47 57 30 31 00 00 00 00
00 00 00 00 00 00 00 00 00 01 01 0A 20 20 00 4B
* Other names and brands are the property of their respective owners. *
NICHOLAS_F_Intel
Hi Jesse,
I've been unsuccessful in reproducing this issue on either Win8* 32 or 64 bit. My suggestion to you is to completely uninstall the graphics drivers you're currently using, deleting the saved version of the file if possible - and then re-installing them via Windows Update.
Let me know how it goes.
-Nic
Hello and thanks for your help Nic.
I have already uninstalled the drivers and reinstalled through Windows Update. I'm not sure what saved file version you are talking about. Where is it?
NICHOLAS_F_Intel
If it didn't prompt you for deleting old driver files when you updated your driver, then that shouldn't be a problem.
Can you provide me a copy of your dxdiag so that I can better try to replicate your system? (Start -> Run -> dxdiag -> Save All information). Just copy & paste the info here and I'll take a look.
-Nic
DxDiag.txt
System Information
Time of this report: 12/4/2012, 10:55:04
Machine name: NEPTUNE
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.121023-1503)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron N4010
BIOS: Ver 1.00 BIOS A11 PARTTBL
Processor: Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz (4 CPUs), ~2.5GHz
Memory: 6144MB RAM
Available OS Memory: 5940MB RAM
Page File: 6410MB used, 1470MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RDPUDD Chained DD
Manufacturer:
Chip type:
DAC type:
Device Type: n/a
Device Key: Enum\ROOT\BASICRENDER
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1366 x 768 (32 bit) (32Hz)
Driver Name:
Driver File Version: ()
Driver Version:
DDI Version: 9Ex
Feature Levels:
Driver Model:
Graphics Preemption:
Compute Preemption:
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-4306-11CF-B278-5C24B8C2C535}
Vendor ID: 0x8086
Device ID: 0x0046
SubSys ID: 0x04561028
Revision ID: 0x0018
Driver Strong Name:
Rank Of Driver:
Video Accel:
DXVA2 Modes:
Deinterlace Caps: n/a
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Not Available
D3D Status: Enabled
AGP Status: Not Available
Manufacturer:
Chip type:
DAC type:
Device Type: n/a
Display Memory: n/a
Shared Memory: n/a
Current Mode: 1920 x 1080 (32 bit) (32Hz)
Driver Name:
Driver Version:
DDI Version: 9Ex
Feature Levels:
Driver Model:
Compute Preemption:
WHQL Logo'd: n/a
Vendor ID: 0x8086
Device ID: 0x0046
Revision ID: 0x0018
Driver Strong Name:
Rank Of Driver:
Video Accel:
DXVA2 Modes:
DXVA-HD: Supported
D3D Status: Enabled
Sound Devices
Description: Remote Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID:
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: {3.0.0.0000000A}.{6C26BA7D-F0B2-4225-B422-8168C5261E45}
Driver Version: ()
WHQL Logo'd: No
Date and Size: , 0 bytes
Other Files:
Driver Provider:
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3B3C
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 9/20/2012 00:55:33, 496872 bytes
| Driver: usbd.sys, 9/20/2012 00:55:32, 21736 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0020
| | Matching Device ID: USB\Class_09
| | Service: usbhub
| +-+ Generic USB Hub
| | | Vendor/Product ID: 0x0A5C, 0x4500
NICHOLAS_F_Intel
Thanks for the info Jesse,
Did you happen to be running this computer in remote desktop when you took the dxdiag? Your display device is not showing up as Intel® HD graphics™ as it should be, and instead shows as RDPUDD Chained DD - which from what I can tell, is how it should show up if you are pulling reports remotely..
-Nic
My apologies. I had a feeling that might affect the program's output, but I got lazy
Here is the updated output:
System Information
Time of this report: 12/4/2012, 11:16:24
Memory: 6144MB RAM
Page File: 6356MB used, 1524MB available
DxDiag Notes
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics (Core i3)
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_04561028&REV_18
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Model: unknown
Monitor Id: INL0014
Native Mode: 1366 x 768(p) (59.996Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.2858 (English)
DDI Version: 10
Feature Levels: 10.0,9.1
Driver Model: WDDM 1.1
Graphics Preemption: DMA
Compute Preemption: DMA
Driver Date/Size: 10/10/2012 14:44:10, 8368576 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x8086
Device ID: 0x0046
Revision ID: 0x0018
Driver Strong Name: oem17.inf:5f63e5349ded771f:iILKM0:8.15.10.2858:pci\ven_8086&dev_0046
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_MOCOMP DXVA2_ModeWMV9_MoComp DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_MoComp DXVA2_ModeVC1_IDCT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
NICHOLAS_F_Intel
Thanks! Looks like your BIOS are out of date, and Dell* is recommending an upgrade. It would be a good idea too since you're running a new OS. Here's the download for your BIOS update; http://www.dell.com/support/drivers/us/en/19/DriverDetails/Product/inspiron-14r?driverId=FXVYN&osCode=W764&fileId=2731102886 http://www.dell.com/support/drivers/us/en/19/DriverDetails/Product/inspiron-14r?driverId=FXVYN&osCode=W764&fileId=2731102886
Let me know if there's any improvement after this, otherwise I'm going to try to reproduce your machine and see if I can get the issue to pop up on my end.
-Nic
I flashed the new BIOS today and it did not make a difference. I am still unable to get into Advanced mode.
NICHOLAS_F_Intel
The Dell* system you're using doesn't yet support Windows 8*. The drivers they have available are for Win7 only. You could be running into issues due to not using your OEM's driver. However, you'll need to switch back to Win7 to do that. Unless your OEM releases a Win8 driver for that system, you'll most likely continue experiencing these issues with the Advanced Mode of the GMCP.
-Nic
JPach4
Hi!
I have the same problem since I have installed the Intel Video Driver and Control Panel 8.15.10.2712 of 22 Jun 2012 (sp57420.exe) - latest driver recommended by HP.com to my Elitebook 8470p / OS.
I don't have SMSC Core Graphics Software installed.
Everything works fine except when I select "Options and Support" in the Intel Graphics and Media Control Panel: an error occurs and it is displayed the message "GfxUI has stopped working" and the Properties Panel must be closed.
Some details of my system:
- Notebook: HP Elitebook 8470p
- OS: Windows 7 Ultimate x64 (service pack 1)
- I have Microsoft.NET framework 3.5.1 active (default by Windows 7)
- I have installed Microsoft.NET framework 4.5.1
Some troubleshooting tentatives (with no success) I have made:
- Uninstalled and reinstalled the video driver;
- Uninstalled Microsoft.NET framework 4.5.1 and reinstalled the video driver;
Can anyone help me resolving this issue, please?
