23586 Discussions
Issues with Elden Ring Nightreign
FIX_NIGHTREIGN
Elden Ring Nightreign can't run on Intel(R) Iris Xe GPUs. The game crashes before start up. It's been over two months and no one's issue with this has been resolved. Please fix this!
Faulting application name: nightreign.exe, version: 1.1.1.0, time stamp: 0x682ec138
Faulting module name: igd12um64xel.dll, version: 32.0.101.6795, time stamp: 0x682c91ff
Exception code: 0xc0000005
Fault offset: 0x00000000000beb40
Faulting process id: 0x954
Faulting application start time: 0x1DBD436277A4BE8
Faulting application path: D:\Games\ELDEN RING NIGHTREIGN\Game\nightreign.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_ebaeaf143648c68b\igd12um64xel.dll
Report Id: 31ee305c-077b-46a8-90ea-18abfef492cf
Faulting package full name:
Faulting package-relative application ID:
JedG_Intel
Hello FIX_NIGHTREIGN,
About your concern on Elden Ring Nightreign while using Intel Iris Xe Graphics, we already did an investigation and based on our analysis, the Intel Iris Xe Graphics does not meet the minimum specifications established by the game developer.
While some users may have been able to run previous versions or similar games, this particular version appears to use updated rendering features that are either not supported or unstable on this hardware. We recommend contacting the game developer directly, as they are in the best position to determine if support or a workaround can be provided.
With this in mind, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Best regards
Jed G.
RafaelBombinha
up
