23095 Discussions
La version mas actualizada para mi grafica integrada
angelquezada
Hola , Tengo un problema tengo un procesador Intel pentium Dual-core E6700 3.20 GHz 3.20 GHz ,y quisiera saber cual es el driver mas actualizado para la gpu integrada del procesado , o si no que tarjetas graficas se podrían usar en una pc con ese procesador para que no haya problemas, porfavor es urgente , ayuda. GRACIAS
AlHill
What operating system?  If Windows 10, there is no driver except the Microsoft generic driver.
n_scott_pearson
If your system has the ability to use an add-in graphics card, you need to look for one that is old enough to be compatible with your motherboard yet is still supported on Windows 10. This is a toughee; your processor is 12 years old. Frankly, your money would be better spent on a newer PC.
