23466 Discussions
Latest 4600 HD for windows 10 installer not working
RMars2
I downloaded latest driver from intel website under this link https://downloadcenter.intel.com/download/25150 Intel® Download Center for my asus G551 but i'm having problem with the installer. When I click setup with or without admin permission, I get this.
With this latest driver I hope it can solve my fn+f5 & f6 (screen brightness) but it seems that I can't even install it on my laptop.
On top of that, I do have any brightness slider either at personalize screen or power option screen.
Can anyone help me with this?
Thank you.
Filip_Z_Intel
You can always try to install the driver with a have disk method - I've seen that Intel support out here made a simple how-to for that method
RMars2
Thanks for your feedback. But I can't even download the driver. It give me Error 404. Neither exe nor zip.
Cesar_B_Intel
Hello Sarafuddin,
The drivers seem to be available now. I was able to successfully download it.
Additionally, you may try the computer manufacturer drivers from their website http://www.asus.com/support/Download/3/714/0/2/SOWE1eRbVetG02i5/41/ http://www.asus.com/support/Download/3/714/0/2/SOWE1eRbVetG02i5/41/
You may try again https://downloadcenter.intel.com/download/25150/Intel-Iris-Iris-Pro-and-HD-Graphics-Production-Driver-for-Windows-10-64-bit Intel® Download Center
Caesar B.
RMars2
I have downloaded the latest driver (15.40.7.64.4279) and when I install it give me this error.
and unfortunately, my manufacturer website still not update their website.
and when i check on device manager, it still show old version 10.18.15.4256.
This brightness control issue is such a pain in the hump ever since this windows launch. Hope we can go somewhere from this.
Thank you.
Filip_Z_Intel
On the 2nd screenshot - use update driver option
And there on the wizard use a have disk method and install a driver
It will work if You have a 64bit Win10 version
And You have to download a .zip file and extract it first
RMars2
Unfortunately it won't work.
Let me share you what i have done and the outcome.
1. update driver --> auto search for update
Result:
2. update driver --> browse my computer --> point to the latest driver directory
Result: Same result as # 1.
3. update driver --> browse my computer --> let me pick ..
The list limited to version 10.xx only which is don't make any sense.
Kindly help me with this.
Filip_Z_Intel
So You did tried it as below and it failed?
RMars2
Yes, i tried this, and it will update to the latest version which I learnt that in 15.40.7.64.4279 the graphic driver would be 10.18.14.4279. Gosh the version numbering quite confusing. And nope. Even with latest driver, I still cant adjust screen brightness with fn or any other place.
Cesar_B_Intel
Hello Sarafuddin,
In this particular case, please try using the Laptop manufacturer's tool (http://dlcdnet.asus.com/pub/ASUS/nb/Apps_for_Win10/Splendid/Splendid_Upgrade_Win10_VER3130004.zip ASUS* Splendid (For Windows 10 Upgrade)) It handles screen brightness and resolution (and some gamma correction) very well.
Please post your results here.
Caesar B.
RMars2
Hi Cesar,
Asus splendid did not work out for me either.
For your information, I already used the latest version for each and every possible hardware like you mentioned but still did not work out.
ATK Package: 1.0.0040
Smart gesture: 4.05
Intel graphic driver: 10.18.15.4279
Nvidia graphic driver: 358.50
What else can I do to solve this brightness control issue?
Thank you.
Cesar_B_Intel
Hello Sarafuddin,
Intel® graphics drivers provided at https://downloadcenter.intel.com/ Intel® Download Center are generic versions and can be used for general purposes. However, computer original equipment manufacturers (OEMs) may have altered the features, incorporated customizations, or made other changes to the software or software packaging they provide. To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer. Intel and the computer original equipment manufacturer (OEM) may not provide technical support for some or all issues that could arise from the usage of this generic version of software drivers.
In this particular situation I suggest contacting the computer manufacturer and confirm with them how to solve the brightness control issue.
Caesar B.
