23682 Discussions
Latest Driver
SLezo
Hello, so when I tried playing some games after installing the newest Driver, my FPS were horrendous, in Counter Strike:GO, I'd get 100 FPS with my 2013 Driver (Modded by the Acer company, PC was already built) and with the 2015 Driver I'd get 30-40 FPS.
I want to see how the middle ground Driver works (2014) but instead of containing the ighdl64, it contains a kit64ics, is that the file I want to use to update my Driver?
Secondary question:
So I get this window:
As you can see there's the 2013 and 2015 Drivers, do I have to highlight one while installing the 2014 one or have nothing highlighted?
Kevin_M_Intel
Hello NChanto,
It is important to say that OEM drivers include special features that will work specifically for your computer. This is why installing the driver from the Computer Manufacture is very important.
You can try installing our generic driver but it does not include the special features from the OEM design. Here you can download the driver from our side:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24596&lang=eng&ProdId=3720 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24596&lang=eng&ProdId=3720
If you have problems during the installation try the steps here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
SLezo
Sorry but this did not answer my questions at all.
A complete other-topic reply you did there.
I simply want to know if the kit64ics file is the same as ighdl64.
I already know how to install.
Kevin_M_Intel
It is a different driver package but it contains same driver at the end.
Kevin M
