22821 Discussions
Latest graphics drivers crash with QtOpenGL QGLWidget
GraphicsDriverTester
We have a Qt application that uses QGLWidget. With most of the new Intel graphics drivers(for eg. 27.20.100.8336 ), we observe that OpenGL calls from this widget gives a floating point exception. This was not the case before, everything was working fine.
I have a Intel HD graphics 620 Card.  Can someone please help me with this.
n_scott_pearson
By "most of the new", which specifically are you referring to? Please try to identify which build introduced the issue.
GabrieleGiuseppini
I get the same with 27.20.100.8280 on the 630. It happens in an OpenGL application after a glViewport call that resizes the view, as soon as glClear or any rendering primitive is invoked (e.g. glDrawArrays):
Unhandled exception at 0x00007FFFD5E834CF (igc64.dll) in FloatingSandbox.exe: 0xC0000090: Floating-point invalid operation (parameters: 0x0000000000000000, 0x0000000000009861).
This happens in my debug builds, when I enable on purpose all floating point exceptions except for INEXACT and UNDERFLOW. Is the driver supposed to generate floating point exceptions?
GabrieleGiuseppini
For those interested ones, I've just installed 27.20.100.8587 and the problem has disappeared. No more floating point exceptions from within the driver!
