23526 Discussions
Linpack result for Intel ® Xeon® Gold 6148 cluster
jbowe6
Node: 4 socket Intel ® Xeon® Gold 6148 Scalable Processors(20Core,150W,2.4GHz)with DRAM 256G
Cluster: 14 nodes
Linpack info: Ns 168000 NBs 384 Ps 1 Qs 1
run with : parallel_studio/mkl/benchmarks/mp_linpack/xhpl_intel64_static
The Max peak for each node is around 4Tflops, compared with the theoretical peak is 6.144Tflops.
The efficiency is 65%, is it low?
n_scott_pearson
This is a technical support forum and not the appropriate place for such queries. I suggest you repost here: Intel Developer Zone forum.
Emeth_O_Intel
Hi James, Thank you for contacting us about this concern. I would like to see if there is anything else that we can assist you with? As per the information provided by Scott the information that you are looking for could be provided by the Intel Developer Zone forum due to the software that you are using is Intel® Parallel Studio and this is support it by the developer zone. Please try to start a request on the following website: https://software.intel.com/en-us/forum. If you have any other question do not hesitate and let us know and I will be more than happy to assist you. Regards, Emeth O. Intel Customer Support Technician Under Contract to Intel Corporation
