23696 Discussions
Looking for help with Raid 5
Okay so I have had a nightmare of a time. I have a 3 disk Raid 5 on ICH10r. One of my disks legit failed making the array degraded. In the process of pulling out the HDD the "L" shaped SATA connector on a functioning HDD snapped off. After I soldered the pins on the HDD & a stripped cable I started the computer. Bios showed two failed RAID 5; named array:1 and array:1:1. Well I followed the steps in this thread /thread/3351 http://communities.intel.com/thread/3351 to no avail atm. I'm 99.99% sure my 2 drives are in the correct order. When I run Testdisk even after a deepscan I get no partitions found... I'm SOL right???
