23768 Discussions
Meego Pad
CLope11
I there, i have a Meego Pad T01 and when I put him in a TV ( (Haier Led TV - LE32B7000T)) in HDMI port, the colors in screem have some noise.
I tried to update the drivers, because meego pad have a intel hd graphics, but i can´t see the drivers to this cpu.
Can you Help me please.
Tanks
Hans_B_Intel
Hello actdl,
You can try installing the Intel drivers, just note that these software drivers are generic versions and can be used for general purposes. However, computer original equipment manufacturers (OEMs) may have altered the features, incorporated customizations, or made other changes to the software or software packaging they provide. To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer. Intel and the computer original equipment manufacturer (OEM) may not provide technical support for some or all issues that could arise from the usage of this generic version of software drivers.
How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
http://www.intel.com/support/graphics/sb/CS-033916.htm http://www.intel.com/support/graphics/sb/CS-033916.htm
HD graphics driver download:
https://downloadcenter.intel.com/download/24972/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32-bit https://downloadcenter.intel.com/download/24972/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32-bit
