23769 Discussions
Message signaled interrupts
yato
I want to disable message signaled interrupts for intel iris xe graphics on my laptop for some reasons but when I disable it gives error and does not load the driver on reboot or on device manager disable and enable is there a way to make it use line based interrupts instead of msi? I see the option line based on msi utility but it doesnt work for some reasons probably interrupt priority handling etc. can someone help me make it line based interrupts
thanks
ArchieD_Intel
Hi yato
  • Is this working fine before?
  • Have you tried using the OEM drivers for testing?
  • Have you checked your BIOS settings if there are any related options to interrupt handling?
  • What are the troubleshooting steps that you tried so far?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
ArchieD_Intel
Hi yato
Archie D.
ArchieD_Intel
Hi yato
Archie D.
