23526 Discussions
Minecraft Crashing on new computer
PCono
Completely ignored arguments: [--nativeLauncherVersion, 301]
[14:35:00] [Client thread/INFO]: Setting user: 8drinkslater
[14:35:00] [Client thread/INFO]: (Session ID is )
[14:35:01] [Client thread/INFO]: LWJGL Version: 2.9.4
[14:35:01] [Client thread/WARN]: Removed selected resource pack Xray Ultimate 1.8.zip because it's no longer compatible
[14:35:01] [Client thread/INFO]: Reloading ResourceManager: Default
[14:35:01] [Sound Library Loader/INFO]: Starting up SoundSystem...
[14:35:01] [Thread-5/INFO]: Initializing LWJGL OpenAL
[14:35:01] [Thread-5/INFO]: (The LWJGL binding of OpenAL. For more information, see http://www.lwjgl.org http://www.lwjgl.org)
AL lib: (EE) MMDevApiOpenPlayback: Device init failed: 0x80070490
[14:35:01] [Thread-5/ERROR]: Error in class 'LibraryLWJGLOpenAL'
[14:35:01] [Thread-5/ERROR]: Unable to initialize OpenAL. Probable cause: OpenAL not supported.
[14:35:01] [Thread-5/WARN]: ERROR MESSAGE:
[14:35:01] [Thread-5/INFO]: Could not locate OpenAL library.
[14:35:01] [Thread-5/WARN]: STACK TRACE:
[14:35:01] [Thread-5/INFO]: org.lwjgl.openal.AL.create(AL.java:156)
[14:35:01] [Thread-5/INFO]: org.lwjgl.openal.AL.create(AL.java:102)
[14:35:01] [Thread-5/INFO]: org.lwjgl.openal.AL.create(AL.java:206)
[14:35:01] [Thread-5/INFO]: paulscode.sound.libraries.LibraryLWJGLOpenAL.init(LibraryLWJGLOpenAL.java:164)
[14:35:01] [Thread-5/INFO]: paulscode.sound.SoundSystem.CommandNewLibrary(SoundSystem.java:1576)
[14:35:01] [Thread-5/INFO]: paulscode.sound.SoundSystem.CommandQueue(SoundSystem.java:2572)
[14:35:01] [Thread-5/INFO]: paulscode.sound.CommandThread.run(CommandThread.java:121)
[14:35:02] [Sound Library Loader/WARN]: ERROR MESSAGE:
[14:35:02] [Sound Library Loader/INFO]: Could not locate OpenAL library.
[14:35:02] [Sound Library Loader/INFO]: Starting up SoundSystem...
[14:35:02] [Client thread/INFO]: Created: 1024x512 textures-atlas
[14:35:02] [Thread-7/INFO]: Switching to No Sound
[14:35:02] [Thread-7/INFO]: (Silent Mode)
[14:35:02] [Sound Library Loader/INFO]: Sound engine started
[14:35:05] [Server thread/INFO]: Starting integrated minecraft server version 1.9
[14:35:05] [Server thread/INFO]: Generating keypair
[14:35:05] [Server thread/INFO]: Preparing start region for level 0
[14:35:06] [Server thread/WARN]: Keeping entity Villager that already exists with UUID 498439fb-f258-457b-a45b-11f1619ad92c
[14:35:06] [Server thread/INFO]: Changing view distance to 12, from 10
[14:35:06] [Server thread/INFO]: 8drinkslater[local:E:514276e8] logged in with entity id 155 at (134.44904963146234, 33.0, -960.4671421860739)
[14:35:06] [Server thread/INFO]: 8drinkslater joined the game
[14:35:07] [Client thread/FATAL]: Error executing task
java.util.concurrent.ExecutionException: java.util.ConcurrentModificationException
at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:1.8.0_25]
at java.util.concurrent.FutureTask.get(FutureTask.java:192) ~[?:1.8.0_25]
at g.a(SourceFile:46) [1.9.jar:?]
at bcf.av(SourceFile:954) [1.9.jar:?]
at bcf.a(SourceFile:392) [1.9.jar:?]
at net.minecraft.client.main.Main.main(SourceFile:124) [1.9.jar:?]
Caused by: java.util.ConcurrentModificationException
at java.util.HashMap$HashIterator.nextNode(HashMap.java:1429) ~[?:1.8.0_25]
at java.util.HashMap$KeyIterator.next(HashMap.java:1453) ~[?:1.8.0_25]
at ny.(SourceFile:26) ~[1.9.jar:?]
at ase.(SourceFile:83) ~[1.9.jar:?]
at bkq.c(SourceFile:48) ~[1.9.jar:?]
at bku.b(SourceFile:169) ~[1.9.jar:?]
at bks.a(SourceFile:605) ~[1.9.jar:?]
at gp.a(SourceFile:64) ~[1.9.jar:?]
at gp.a(SourceFile:12) ~[1.9.jar:?]
at fh$1.run(SourceFile:13) ~[1.9.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_25]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_25]
at g.a(SourceFile:45) ~[1.9.jar:?]
... 3 more
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff8e9fb65c7, pid=7056, tid=9816
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig9icd64.dll+0x165c7]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\Paul\AppData\Roaming\.minecraft\hs_err_pid7056.log
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Have Intel HD Graphics 530. Works fine with earlier versions of Minecraft but not recent update. This computer is a week old HP Envy with an i7 6700 processor. IDK what other info you need.
Hello, 8drinkslater:
Thank you for contacting the Intel Communities.
As per the report provided, it looks like you have an error related to java, here you can find some troubleshooting for that error: https://www.spigotmc.org/threads/minecraft-64bit-java-error-exception_access_violation-0xc0000005.32934/ https://www.spigotmc.org/threads/minecraft-64bit-java-error-exception_access_violation-0xc0000005.32934/
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
If the problem persists after this, please report the bug to the developer of the game since the update of the game is causing the issue, I would say it is more related to the game than to the graphics driver.
If you require any further information or support, feel free to contact us back.
Thought I would just check in and find out if you were able to resolved this problem.
I look forward to hearing from you.
Esteban C
