23854 Discussions
Minecraft Crashing
VVert
Completely ignored arguments: [--nativeLauncherVersion, 301]
[21:35:38] [Client thread/INFO]: Setting user: Vice_Vertex
[21:35:40] [Client thread/INFO]: LWJGL Version: 2.9.4
[21:35:40] [Client thread/INFO]: Reloading ResourceManager: Default
[21:35:41] [Sound Library Loader/INFO]: Starting up SoundSystem...
[21:35:41] [Thread-5/INFO]: Initializing LWJGL OpenAL
[21:35:41] [Thread-5/INFO]: (The LWJGL binding of OpenAL. For more information, see http://www.lwjgl.org http://www.lwjgl.org)
[21:35:42] [Thread-5/INFO]: OpenAL initialized.
[21:35:42] [Sound Library Loader/INFO]: Sound engine started
[21:35:43] [Client thread/INFO]: Created: 1024x512 textures-atlas
[21:37:22] [Client thread/INFO]: Connecting to mc.skylair.net, 25565
[21:37:24] [Client thread/INFO]: [CHAT] Hello, Vice_Vertex!
[21:37:24] [Client thread/INFO]: [CHAT] ------------------------------
[21:37:24] [Client thread/INFO]: [CHAT] Type /help for a list of commands.
[21:37:24] [Client thread/INFO]: [CHAT] Players online: 1
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffaaac8a41c, pid=7916, tid=8792
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig9icd64.dll+0x57a41c]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\Charlie O'Leary\AppData\Roaming\.minecraft\hs_err_pid7916.log
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
AL lib: (EE) alc_cleanup: 1 device not closed
Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
So i bought minecraft almost two weeks ago from now and its worked fine, but now whenever i try to do anything it crashes on me (everything above). i keep logging on and whatnot, after many tries it'll work but then crash sometime after. now i dont know much about computers or anything so im hoping someone will be able to help... i believe i have the Spectre Windows10 64bit, intel i7 and its fairly new, i got it after christmas around late january.
FHeik
New Contributor II
Since your problem appears to be game-related, my suggestion is to consult the official https://help.mojang.com/ Minecraft support site, and/or post in the http://www.minecraftforum.net/forums Minecraft forums ('Support' section).
Hello, All:
YseGuy, thank you for your feedback.
@Vice_Vertex, try the suggestion mentioned above. If the issue persist please provide me with the following;
  • Intel® HD Graphics driver version installed. Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
  • BIOS version.
  • Computer model.
  • CPU model.
  • Operating system and the build version.
  • Minecraft version.
Amy.
Hello, @Vice_Vertex:
Were you able to fix the issue?
Let me know your findings.
Amy.
