23481 Discussions
Missing display updates with Intel Iris XE
EckartRS
In our WPF application we have an update problem, which only appears on PCs with the Intel Iris XE graphics card.
In the application there is an animation done by the use of a System.Windows.Media.Imaging.WriteableBitmap, attached to a System.Windows.Controls.Image as "Source"
NO display update is seen on PCs with the Intel Iris XE graphics card, while it works well with other PCs. An update ist only seen, when for e.g. the window is resized.
Looks like a driver problem, but we already installed the most recent display driver.
examples according to  https://docs.microsoft.com/de-de/dotnet/api/system.windows.media.imaging.writeablebitmap?view=net-5.0
m_myWriteableBitmap.WritePixels(UpdateRegion, m_PixArray, 4 * 100 /* stride */, 0 /* offset */);
does not lead to the expected display update.
A full test project is attached
Thanks very much for any hints
Eckart
DeividA_Intel
Hello EckartRS,
Based on the information provided, please try the following:
1. Take a picture/video of the issue.
2. Update your Windows version.
3. Check for BIOS updates.
- https://www.dell.com/support/home/en-us/product-support/product/latitude-14-7420-2-in-1-laptop/drivers
4. Try a manual installation of the Intel driver.
- Driver: https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-10-windows-11-dch-drivers.html
- Steps: https://www.intel.com/content/www/us/en/support/articles/000057389/graphics.html
5. Have you reported this issue with DELL?
Deivid A.
DeividA_Intel
Hello EckartRS,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html?v=t
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Is this issue recent? If so, when did it start?
3. Does the new version appear in the device manager?
4. Did you receive any kind of errors? If so, which ones?
5. Can you take pictures/videos of the issue?
6. What is the full name of the app/tool that you are using?
7. Can you share any extra details of the issue?
Deivid A.
EckartRS
Thank you very much.
1. I have attached the result of the SystemSupportUtility.
2. This is issue is present for at least half a year, probably longer. It appears also on a second systems with Intel Iris XE graphics
4. No errors appear in the software, you only see, that a display update is missing.
5. A moving diagonal line is expected, but a blank white screen is seen.
6. - 7.  the simplified app is attached (WpfAppDynamicImages.zip), which contains code snippets from MSDN
Thank you very much
DeividA_Intel
Hello EckartRS,
Deivid A.
DeividA_Intel
Hello EckartRS,
Were you able to check the previous post and try the recommendations? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello EckartRS,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
EckartRS
Thanks for your hints. Unfortunately, this problem does not arise on my place, but at a customer on a different location, so we could not update bios or manual driver installation by now. I will try to get a hardware, that I have direct access to, and do this.
EckartRS
Just as update,
the customer could meanwhile do the installation of drivers from the site
 https://www.dell.com/support/home/en-us/product-support/product/latitude-14-7420-2-in-1-laptop/drive...
and this indeed solved the problem
The new  driver of the Intel Iris XE  is  27.20.100.9749  (Date 24/06/2021)  seems to fix it.
Thank you very much
best regards
Eckart
