23784 Discussions
Model NUC11PAH
Ihsan
the screen often turns off then the display turns blue and a few moments later the screen looks like a broken tv
Alberto_R_Intel
Ihsan, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
Is this a new Intel® NUC?
When did you purchase it?
What is the model of the TV?
Which video port are you using to connect the Intel® NUC to the screen?
Are you using adapters or converters to connect the TV to the monitor?
Was this Intel® NUC ever working fine before with this same TV?
If so, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Alberto_R_Intel
Hello Ihsan, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello Ihsan, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
