23651 Discussions
Monitor/GPU not displaying video properly
amccpf
I have recently built a pc and paired it with a Philips 243v7QDAB monitor. I have an Intel Arc 750 as a GPU with the newest drivers installed.
I shoot 10 bit video and when i play it on VLC or other video player there is distortion like the one you can see on the shirt (link below) How can i fix this ? Is it a monitor or GPU issue ?
https://gyazo.com/f0f5ea7462c1d31a7609bc4f796f49c5
Jean_Intel
Hello amccpf,
Thank you for posting in the Intel community. We understand that you are experiencing issues when reproducing 10-bit color videos. We would be more than happy to help you; hence, we would like to request more details to better assist you:
  • You mentioned that your graphics card model is the Intel Arc 750. However, we would like to confirm your graphics card manufacturer. Is it a Limited Edition Card?
  • Unfortunately, we are unable to access the link you have provided, and we can't take a look at what you've shared. Is it possible for you to share it on the thread directly?
  • Is it possible for you to try and reproduce the video on another system? You mentioned that the error is when reproducing the video, and it is present in multiple applications, so it may be a software problem, but we would like to discard that the problem is related to specific software in the affected system.
  • We would like to have more details about your system. Please, share with us the system reports using the Intel®️ System Support Utility (Intel®️ SSU):
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
Best regards
Jean O.
Jean_Intel
Hello amccpf,
We are checking on your thread to see if you have been able to gather the information provided. Feel free to let us know if you have any other questions.
Best regards
Jean O.
Jean_Intel
Hello amccpf,
Since we have not received a response from you, we will proceed to close this thread. If you need additional support, open a new question as this thread will no longer be monitored.
Best regards
Jean O.
Jean_Intel
Hello amccpf,
We are jumping into this thread to inform you that before we closed the thread, we tried to replicate your issue internally; however, we have not been able to replicate the issue you described. We played the videos provided in different video players, but there was no corruption or problem, and all the videos played with no problem. If you want, you can take a look at this video we recorded when replicating the issue.
Now, we will proceed to close this thread. If you need additional support, open a new question, as this thread will no longer be monitored.
Best regards
Jean O.
