22848 Discussions
Monitor does not sleep with Intel HD4600
MMiha5
Hello.
I recently bought a laptop and I use it with a Benq 24inch monitor via HDMI. The problem I have is the monitor does not sleep when Windows commands it ( it goes black and the backlight is on). I tried all the settings in power options and in BIOS I did not find any settings regarding video or power settings. The problem is not from the cable/monitor for sure because it works well with a Toshiba laptop that uses an Ati hd4650 video card.
The laptop informations are:
Intel i3-4000m
Intel hd4600+ati 8750m
Windows 7 64bit
Thanks !
Silvia_L_Intel1
Hello Matt90, thanks for contacting us through the Intel Communities.
Please test the system using the latest graphics driver's version 3621.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23884&lang=eng&OSVersion=%0A%09%09%09%09%09%09%09%09%0A%09%09%09%09%09%09%09&DownloadType=Drivers Intel® Iris™ and HD Graphics Driver for Windows* 7/8/8.1 64-bit https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23884&lang=eng&OSVersion=%0A%09%09%09%09%09%09%09%09%0A%09%09%09%09%09%09%09&DownloadType Download Center
If the issue persisted, please check if there is a new BIOS version available for your laptop.
MMiha5
It seems I cannot install the beta driver... It says it cannot be installed on this computer, please contact the manufacturer(Lenovo in my case). I also tried some old drivers but still cannot install them. I`m starting to feel bad I bought Lenovo.
MMiha5
I tried to install the latest 64bit driver : https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23885&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers Download Center
When I try to update it from device manager Windows says I have the latest driver and does not update. I tried to intall it from the unzipped folder running setup but I get this message:
MMiha5
Update: With VGA cable the external monitor does go to sleep.
Silvia_L_Intel1
Have you tried using another HDMI cable?
