23757 Discussions
Monitor doesnt recognise on boot
MShus1
Hello!
Previously I used my pc with two monitors connected directly to motherboard and everything worked fine using hdmi and vga.
Then, I installed gtx 570 into my computer and installed drivers And system worked with 2 monitors perfectly.
Now I removed graphics card and uninstalled drivers.
and issue is, windows only detects my first monitor which is connected via vga. second monitor is off. to turn it on I need to go to my intel hd graphics settings and press find(screenshot), and monitor turns on. after reboot my computer forgets monitor again. I tried reinstalling intel graphics, restoring default bios settings, it didnt help. I tried to boot in linux and it detects both monitors.
mobo: H110M PRO-VH
windows 10 64 bit
latest bios
Stefan3D
"Restore from a system restore point" as described at
https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options
Otherwise check BIOS Settings / Advanced / Integrated Graphics Configuration / IGD Multi-Monitor.
MShus1
Hello! thank you for reply. recovery options were not working. they were grey, couldnt use them.. I reinstalled windows completely and issue persists.
I checked bios - I have IGD and other option (PEG i believe), but no IGD multi-monitor..
LeonWaksman
In the bottom part of the Intel Display Panel you have three options: Save Profile, Cancel and Apply. So, after you have pressed on Detect and the second display is detected, pres on Apply and then on Save Profile.
Hope this helps
Leon
MShus1
Hello! thanks for reply. It didnt help me. after I rebooted, only 1 monitor was enabled, after i opened intel display panel and chose my profile.. intel stuff just crashed. i tested that scenario multiple times, it does it all the time.
MShus1
bump
Hello mshustov
I was checking on your case, could you provide us with the following information:
Can you provide us with the Dxdiag report following these steps?
  1. Use the win logo key +R
  2. Type DxDiag then "OK"
  3. Use the "save all the information" option
  4. Save the file to your desktop
  5. Please attach the .txt file to the thread
Could you describe the video connection that you have? Type of cables, adapters (if there are any)
What are the models of the displays?
What is the BIOS version installed on the system?
Leonardo C.
Hello mshustov
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
