23801 Discussions
Monitor max refresh rate UHD 730
Austin47
I'm been using the intel UHD 730 onboard graphics with my alienware 240hz 27" monitor with no problems  running 240hz on my Old Msi z690 tomahawk ddr4.
2560x1440 res / using DisplayPort cable
i have just switched motherboards to a gigabyte b760 aorus master ddr4
but i can only go high as 200hz no matter which driver or windows settings no options settings for 240hz like my old board 😞
I could choose 240hz on my old msi z690 even without drivers installed (just basic windows drivers)
Do you know if it's a limit with the b760 chipset or can it be  motherboard problem ?
I also tried a clean install of both windows 10 and 11 but no difference
Thank you Austin
Gigabyte b760 aorus master ddr4
i5 12400
32gb Crucial ddr4 3200
Corsair ax760i psu
Hugo_Intel
Hello Austin47
We understand you have opened a (chat/email/phone) support case with us, and we will continue to help you through that channel now. We will therefore close this community case. Please, keep in mind that this thread will no longer be monitored by Intel, in case that you have further questions, please open a new thread.
Thanks for your understanding.
Hugo O.
