23699 Discussions
Monitor not working only DisplayPort
helpwithmonitorpls
My monitor is not working with my display port.
I have a GTX 1050 and an i7-7700HQ
I don't know why but my monitor sometimes just turns off and says DisplayPort no signal.
The HDMI works. It is linked to my GPU but DisplayPort is linked to Integrated Graphics (Intel 630) so that has  made me think that there is a problem with the GPI
All drivers are up to date and (I know this sounds stupid) everything is plugged in to the right places.
Also, my monitor is hooked up to my laptop which does work and supports the 144hz and dual-monitor display.
My monitor is an Asus VG248QE and it is not recognised in anything when using DisplayPort but is detected when I use HDMI
helpwithmonitorpls
SOLVED
I just needed a new wire
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (look at the instruction under the reply window).
Doc
Daprez008
I am having the same issue. I have a core I5 6600 with a  HD Graphics 530. All drivers are up to date and my HDMI / DisplayPort cable is good. Can someone please help me fix this.
