22973 Discussions
Moving applications when monitors are powered off
I have two monitors and I like to turn them off when I go home from work, but when I turn them on in the morning all my applications have moved monitors because my intel P4600 integrated graphics driver moves all the applications to the monitor I turn on first.
I would like to be able to disable this feature so when I turn my monitors back on my applications are in the same place I left them.
In the mean time, if anybody has a workaround they can tell me, it would be much appreciated.
Douglas.
Thank you for reaching the Intel Communities.
I understand it is important to have the windows arranged as desired for you, this is a known problem that some users have experienced and it is being worked on.
At this point, I would like to gather up some data from your system to have a clear understanding of the scenario you are currently facing.
Please attach the report from the link below.
That report with gather up some basic information of the system related to graphics, OS and drivers used.
Esteban C
This is to do a follow up on your case and find out if you were able to check my previous post.
Esteban C
Thanks for the replies!
Please find attached the results of my system scan.
Douglas.
Thank you for the information provided
In this case, I would like you to test the system with our latest generic driver.
This is the link to download it: http://intel.ly/2z8flZw http://intel.ly/2z8flZw
Find the steps to install it attached.
1. Extract the files with right click> extract all
2. Access the device manager
3. Follow the steps from the pictures
Let me know how it goes.
Esteban C
Have you got any information on how the new driver might solve my problem, like a release note or something?
Douglas.
The reason behid my recommendation is that I want you to have the latest graphics drivers installed to find out if the problem is present or not.
Depending on the results I would proceed accordingly.
Were you able to get the driver 4703 installed? If so, how did the system behave?
Esteban C
This is a follow up to your post to find out if you were able to check my previous answer.
Esteban C
