23808 Discussions
My Intel Graphics Control Panel wont open
BHaml
I have had this problem since Ive had my pc. I didn't really care at the time because i had no need to open the panel but now i do need to open it. So what happens is i click on it, i see it for a split second, and then it closes again. I really don't know whats happening and i need help. I have an Intel(R) Core(TM) i7-4790 CPU @ 3.60Ghz.
Hello Benjamin55,
I understand the Intel Graphics Control Panel is not opening.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred
Hello Benjamin55,
I am wondering if you still need assistance regarding the Intel Graphics Control Panel which is not opening. In case you still need assistance just let me know.
Fred D.
