23793 Discussions
My Intel HD graphics control panel is missing...
SMAHE6
I am having Alienware 17 r4 running windows 10, I did factory reset , and installed all drivers but I am not able to find Intel HD control Panel, and moreover there is no option to switch between graphics in Nvidia control panel, even optimus technology has been removed
VARADHARAJAN
Valued Contributor II
​Just I now I seen the technical specifiactions  of your  model  , and I found that  dell released  intel graphics  driver  22.20.16.4836 ,A04  and  for  NVidia graphics driver
23.21.13.9125 ,A12   .
But I found  old intel version 22.20.16.4708  installed   and  also  NVidia   generic version 25.21.14.1735 you  installed .
so I would  you recommend  install the drivers  from dell .
Before installing driver , uninstall those  completely by using revo uninstall  software  , then install  both the drivers
SMAHE6
the intel driver you specified is for 500,p500,600 and p600 series but mine is 630. when installing the system gives a error saying that it does not meet the minimum system requirements
VARADHARAJAN
sir , will you give me link of your model dell laptop as indicates drivers page
VARADHARAJAN
morning I seen same page , you can find these sentences on that page
Intel HD Graphics 630 Driver for Intel R Core TM i5-7300HQ /i7-7700HQ /i7-7820HK
Video20 Dec 2018 Download Importance: Recommended
Version: 22.20.16.4836 ,A04
Release Date: 29 Dec 2017
File Name: Intel-HD-Graphics-630-Driver-for-Intel-R-Core-TM_JV5V4_WIN_22.20.16.4836_A04.EXE
File size: 291.06 MB
SMAHE6
yeah, i tried to unistall intel graphics driver through revo uninstaller but couldn't find so i uninstalled through device manager also removed nvidia graphic driver through revo uninstaller and then installed the latest intel graphic driver driver but i couldn't find control pannel and also i can see gpu0 in task manager saying intel hd 630. but there is no control pannel and in display setting it says display1 connected to microsoft basic display adapter. at this time nvidia was not installed if i install nvidia graphic driver, it says display1 connected to nvidia...
SMAHE6
also the hot keys are disabled, like i have a key to switch between integrated and dedicated graphics , dat key no longer works properly, but my nvidia dedicated driver is working properly.
SMAHE6
thank you...my problem got solved , i unistalled the nvidia driver and used the key(i/d gfx) to switch from microsoft basic display adapter to intel hd graphics and then installed nvidia, now everything is back to normal
