23797 Discussions
NPU in WSL
Peter_Cs
Hello Experts,
I would like to create a WSL (Ubuntu (Default) / Ubuntu 22.04) Python development environment, where I can use the NPU device of my Win11 notebook (Intel(R) Core(TM) Ultra 9 185H 2.50 GHz).
Unfortunately, I can't put the NPU through, so it is not listed in dmesg nor after the lspci command.
My WSL --version:
WSL version: 2.1.5.0
Kernel version: 5.15.146.1-2
WSLg version: 1.0.60
MSRDC version: 1.2.5105
Direct3D version: 1.611.1-81528511
DXCore version: 10.0.25131.1002-220531-1700.rs-onecore-base2-hyp
Windows version: 10.0.22631.3296
The GPU (Intel ARC) driver version is: 31.0.101.5126
The NPU driver version is: 31.0.100.2016
Is there any solution for using the NPU in WSL?
I did some research but could not apply any of the followings (because the device is not listed in the WSL, like /dev/accel/accel0):
https://community.intel.com/t5/Blogs/Tech-Innovation/Artificial-Intelligence-AI/Accelerating-AI-applications-on-Windows-Subsystem-for-Linux-with/post/1401721
https://learn.microsoft.com/en-us/windows/ai/directml/gpu-pytorch-wsl
https://github.com/intel/linux-npu-driver/releases
https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-linux/2023-0/configure-wsl-2-for-gpu-workflows.html
Thank you for your help in advance!
Peter
Uvoltan
wow still no reply :<.. i have same issue. i cannot use npu even i have the npu part in my notebook
Stefan3D
I think there is the same limitation as with the GPU which works through DirectX translation layers.
You might have noticed in your favourite GPU tool that it shows a MESA DZN driver under WSL, but not the native Windows driver.
The only thing i could imagine is DirectML on WSL in the far future 🤔
ap2121
hello, are there any updates on this?
RickRichmond
