23282 Discussions
NUC M15 - How to activate num lock ?
JustinBacle
Hello, stupid question here maybe, but I can get to use the num lock function on my NUC M15 (LAPBC710). I suppose I should activate it by pressing the Function key + the "num lock / scroll lock" button it does nothing.
Note that pressing the "num lock / scroll lock" button without any other key does activate scroll lock as expected.
Thank you
(Btw extremely sad that the NUC laptop will not be renewed, really love it)
DhannielM_Intel
Hello JustinBacle,
Thank you for clarifying this for me. I've found another set of steps we can try to see if they resolve the issue. These steps are somewhat similar to the first article I provided, but I want to explore all possible solutions to address this problem. Please follow the steps below to enable the number pad:
  1. Boot the system
  2. Press F2 during start to enter BIOS Setup.
  3. Select Advanced> Onboard Device.
  4. Set Integrated Numpad (Fn hotkey) option to Enable.
  5. Press F10 to save and exit, the NUC will auto reboot.
Toggle Integrated Numpad via Fn+Num after startup to Windows operating system. Then see if tthe issue will be resolve.
Dhanniel M.
DhannielM_Intel
Hello JustinBacle,
Thank you for posting in the community regarding your concern with the num lock. I wanted to confirm whether pressing the Fn key and NumLock results in any LED light appearing on your laptop keyboard.
Additionally, you might want to try the following steps to see if they help resolve the issue: Cannot Enable NumLock on Intel Laptop
Dhanniel M.
JustinBacle
Hi Dhanniel,
Thank for your support.
There is no led on thekeyboard on the NUC M15, but using the windows on-screen keyboard, I can confirm that Fn + Numlock does nothing, while the other locks (Caps Lock,  Scroll lock) work fine.
n_scott_pearson
Just saying, there are multiple laptop families that answer to 'NUC M15', so it's not a sufficient way to identify your laptop. You can use the full product id (LAPBC710) or you can generalize to the family code BC (Bishop County).
I have the LAPRC710, family RC (Rooks County), and pressing Fn+NUMLK lights up the LED built into the SCRLKL/NUCLK button.
Hope this helps,
JustinBacle
Good remark, mine is indeed LAPBC710, and Fn + numlock does nothing.
DhannielM_Intel
Hello JustinBacle,
Thank you for letting me know, and I appreciate your suggestion for this thread, @n_scott_pearson. Given the situation, I wanted to check if you've followed the steps outlined in the public article I shared with you.
Additionally, I'm curious about your LAPBC710 laptop, as I recall it doesn't have a numpad, only the number keys at the top. Could you explain why you want the numlock LED to be on? For clarification, if the numlock LED is activated, it typically means the number keys at the top cannot be used.
Dhanniel M.
JustinBacle
Hey Dhanniel, unfortunately, the article you recommended does not relate to my product type.
As the keyboard has numbers on it, I'm supposed to be able to use them by using num lock, then using the numbers written on the keyboard (Keys, 7, 8, 9, U, I, O, J, K, L and ? on my Azerty layout keyboard), see picture.
It's definitely something that works on all other laptops I used before and is useful for excel and working with numbers in general.
DhannielM_Intel
Hello JustinBacle,
  1. Boot the system
Dhanniel M.
JustinBacle
Thank you, that works great. So weird it was not enabled by default. And there is even a small LED on activation now!
Now if you'll excuse me, I have some number crushing to do.
DhannielM_Intel
Hello JustinBacle,
I'm pleased to hear that my recommendation resolved the issue with your NUC keyboard. Since the problem has been fixed, I will proceed to close this inquiry. Best of luck with your number-crunching! If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored.
Dhanniel M.
