22945 Discussions
NUC10i7FNH not recognizing second display on displayport
MMose9
I have a NUC10i7 with integrated intel UHD graphics. I connected a second display via the USBC to displayport cable. The second monitor is not recognized (second monitor set to displayport input). I do not see any updated drivers available. Any ideas?
n_scott_pearson
Is this USB-C cable compliant with the USB-C (DisplayPort Alternate Mode) and Thunderbolt 3 specifications? I have a compliant USB-C-to-HDMI dongle and am able to run with two 1080p monitors just fine.
Aside: I also have a compliant MST Hub (USB-C-to-2x-HDMI). With it, I can have two 1080p monitors connected to (sharing) the USB-C output. This brings total to three monitors!
MMose9
Thanks. I changed cables and solved the problem. Should have tried that first!
GregMihran
I just purchased an Intel NUC10i7FNH and have the exact same issue. How did you solve the problem? Which adapter and/or cable did you use? I would like to run two 4K monitors. I have one in the HDMI port so far.
