23851 Discussions
NUC10i7FNK
Gigiusia
Salve , ho installato un gioco , nello specifico "rise of the tomb raider" , non si riesce a giocare , va lentissimo .
Il problema in qualche modo si puo' risolvere ?
Grazie in anticipo
AndrewG_Intel
Hello Gigiusia
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer being monitored.
Andrew G.
LeonWaksman
You may improve the performance only if using External GPU (NVIDIA or AMD). NUC10i7FN is not a gaming computer. See this Recommended System Requirements.
Leon
Gigiusia
Buongiorno.
Quindi con un NUCi7-8705G che ha una scheda AMD non ci dovrebbero essere problemi .
Grazie mille
AndrewG_Intel
Hello Gigiusia
Thank you for posting on the Intel® communities. Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool.
We are checking this thread and we would like to know if you have additional inquiries. Please do not hesitate to contact us back.
Andrew G.
AndrewG_Intel
Hello Gigiusia
Andrew G.
