23469 Discussions
Need for Speed 2016 not run on iGPU 4600 !
r3un1on
Hallo,
if i start the Game, it Show a message my Intel Driver Version is 4332 ! (the recommended Driver is Version 4251) !
Also my installed Intel Driver is the lasted Driver for Windows 7 x64.
And if i ignore the message and start the game, it Show the Intro and then freez !
I can only Close the game with Windows Task Kill.
Please fix it !
My System:
Asus Z97-Pro
Intel i7-4790k
GSkill 16GB DDR3 2400MHz
Soundblaster Z
Windows 7 Ultimate x64
Intel Driver Version 4332
Hello igpu,
Thank you for joining the Intel communities.
You can try installing the Intel Beta driver, you can download it here:
https://downloadcenter.intel.com/download/25848/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-?v=t https://downloadcenter.intel.com/download/25848/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-?v=t
If this driver version does not work for you please try with an earlier version, you can download it at the following link:
https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-
Please uninstall the older driver first and then install the one from the link above.
Best wishes,
Ivan
r3un1on
Hallo Ivan,
Thank you for your Answer.
The beta Driver dose not support iGPU 4600 under windows 7. is only for windows 10.
I have found a solution to start the game. If Game Controller is not connected, That happens only when i start the game with intel GPU.
Now i installed windows 10 and installed lasted beta Driver version 4404. The problem is still there.
But ok i think this is Bug from Game.
I found now another problem...
during play, the display goes white color. I think that's reflection error. Intel or EA need to fix it.
Can you please test it ?
At this point, you can run this game with the Intel 4600 graphics and if it runs ok that's great, but bear in mind that this game requires more graphics than the 4600 you have, you can check the minimum and recommended requirements for this game at:
http://www.systemrequirementslab.com/cyri/requirements/need-for-speed-rivals/11870 http://www.systemrequirementslab.com/cyri/requirements/need-for-speed-rivals/11870
Ivan
I've the same issue the moment I start driving the screen goes white in color and nothing can be seen.
I have
intel hd 4600 iGPU
i5 4590
8 gb ram
asus h97 plus
I updated the drivers still no fix
I think it's a bug by EA,
Intel or EA needs to fix this.
Cheers
r3un1on
also i upgraded my CPU to skylake i7-6700k (iGPU 530) and now i have not more this issue.
But if my Gamepad is not connected to my pc, my Keyboard not work and i cant start the game after Intro !
Intel or EA Need to fix it.
Please Report this issue to Intel Driver Teams !
Thank you for your feedback and for letting me know that the game now works fine with Intel® i7-6700k processor.
Dexterousgaming please take into consideration the minimum requirements for this game according to its developer:
Need For Speed Minimum System Requirements
OS: Windows 7 64-bit
CPU: Intel Core i3-4130 or equivalent with 4 hardware threads
RAM: 6 GB System Memory
VRAM: 2GB Graphics Memory
GPU: GeForce GTX 750 Ti 2GB or Radeon HD 7850 2GB
HD: 30 GB available space
DX: DirectX 11
Input device: Keyboard and mouse or Xbox One controller
NET: Online Only (EA's Origin client only)
This game needs at least 2GBs of dedicated video memory (our maximum supported graphics memory is 1.7 GBs and this depends on the OEM), and also the minimum video card is a GeForce GTX 750 Ti 2GB or Radeon HD 7850 2GB being both video cards high performance level.
Also, we have a tool to load the best configurations on your system for each specific game, you can get it at: https://gameplay.intel.com/ https://gameplay.intel.com/
Thanks in advance for your understanding.
Ivan
r3un1on
Hi Ivan,
the Minimum System Requirements, also 2GB Vram you Need, if you want Play this game with 1920x1080 Resolution and High Quality.
If i we Play with 1280x720 and lowest Quality, 1GB Vram is enough for this Setting.
This game is on Intel hd graphic 4600 playlable. i Think white Screen issue is a Driver Problem. It need a fix.
Thank you for the information you have kindly provided.
At this point we will need to wait for a new driver to come up to see if it has any fixes for this but I can't guarantee anything.
Please see supported games for the i5-4590 (Intel HD Graphics 4600) here:
https://gameplay.intel.com/HardwareGames/80810/Intel%C2%AE%20Core%E2%84%A2%20i5-4690%20Processor%20(6M%20Cache,%20up%20to%203.90%20GHz) Check out the games optimized for your graphics:
Ivan
