22888 Discussions
Need help with my graphics....
Alright so I recently installed FIFA 13 but i realized that it won't work on my laptop. Its strange as all the previous versions of the game - FIFA 12, FIFA 11- worked well on my laptop. Someone said it might be the problem with the graphic card. I have Intel HD Graphics (obviously not rendered for hardcore gameplay) but I played Call of Duty - Black Ops and Modern Warfare 3 on this laptop. But FIFA 13 just crashes.
So these are the pics about my graphic details and is there any way by which I can increase the DEDICATED VIDEO MEMORY???? If so please guide me through the process.
I mean, I tried to play the game, but the same problem.. It just takes me to the desktop when I try to play it.
Maybe I have another problem. You see, I can start the game, I'm not sure if you've ever played FIFA, but when I try to play the match it just shuts the game. And like this every time.
http://www.youtube.com/watch?v=wtLS-EWGP6o http://www.youtube.com/watch?v=wtLS-EWGP6o
And yes I know, there is a solution for this, this Alt+Tab thing, but it doesn't always work and it's very annoying to do so every time.. If there is a solution, I would really appreciate it if you could tell me.
NICHOLAS_F_Intel
I couldn't tell in that video what the crash was. No matter though - when you attempted to install your drivers, was it able to successfully install? To check; Start -> Right click 'Computer' and select 'Manage'. From there, choose 'Device Manager' on the left tab, and expand the option for 'Display Adapter'. Double click on your installed display adapter and check the 'Driver' tab. Is the version installed one that matches the file you downloaded (.2622)?
If the driver was successfully installed and still isn't working, try one of our drivers from the download center.
For 64 bit OS: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22082&lang=eng Download Center
For 32 bit OS: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22081&lang=eng Download Center
Yes, it's the same I just downloaded. Okay, I will try to download from the download center. And btw, I have 64 bit OS.
Still doesn't working.. Any other ideas? 😕
NICHOLAS_F_Intel
Is there anything in this article that might pertain to your situation?
https://help.ea.com/article/fifa-13-crashes-on-pc EA Help FIFA 13 Crashes or Freezes on PC
No, I've seen this article and lots of others also.. I don't have any idea what's wrong. Maybe the game doesn't support intel? Is this possible also? The box says that minimum supported video cards are ATI Radeon HD 3600 and NVIDIA GeForce 6800 GT but Intel isn't mentioned there.
